Saw/expansion joint pourable filler?
TonyG
Pennsylvania
Any pourable joint compounds you folks like? I've somewhere close to 450 linear feet to close up, about 1/4'' wide and I'll probably buy a backrod or filler to help.
Thanks, Tony
HotrodHR
North Alabama
How deep is the joint? Personally, I think the joints add interest to the floor, even when epoxied. At a 1/4" wide if they're not too deep you let the epoxy run down into the groove. But if you want it perfectly flat you'll need caulk recommended for concrete by the flooring manufacturer.
Good luck...
T
TonyG
Pennsylvania
I've heard that as well about the cuts, I prefer seemless and without the dirt catching valleys.
Cuts are more in the 2'' range, I was going to stuff cheap 1/4" foam backerod as a filler.
-I'm coming up with these so far:
-Legacy HD 821
-Liquatile 1184
-BondTite 1101
IntegraFlex 1921
LegacyIndustrial
deerfield, IL
