torqueman2002
Even a blind squirrel finds an acorn once in awhile.
I called several days ago, no answer on 1st number & 2nd number's mail box was full. Oh well, another Baldor through my fingers.
Yesterday, though it was back at the top of the search list. So what the heck, I called and Wally said come on over.
1/2 HP Single Phase, 5/8" Arbor, 8" wheels.
Of course it didn't run, but I didn't feel any play or roughness in the bearings. I gambled $55 and got a new project. Here are pics with a little Kroil sprayed on the label to get a better picture. I don't know if it'll make a good buffer, but without wheel guards, tool rests, eye shields, and spark arrestors; I'm sure not thinking of grinding or wheeling as it is.
It has an adjustable home made stand. The base is 3/8" steel with a pipe welded to it, and another pipe fits inside with a 2nd plate drilled for mounting the grinder. The bottom feels like it weighs ~ 100#.
Quick look shows it needs a new cord and switch. I'll open it up and do a refresh or rebuild depending on what I see. Oh, there is a repaired crack on the base, below the RH grinding wheel.
It needs work, but after the 1 HP CM Block Grinder rescue (Go-Blue), I don't scare easy.
I've been looking for a Baldor for a very long time, around here you can't touch anything for under $125.
I sent off an eMail to Baldor, asking for more information on the grinder; ie: manufacture date, parts price list, .... .
It may be heresy, but there's a thread here where some one adapted CM wheel guards ($7), etc ... to a Baldor; until Baldor replacement parts could be found.
I should be working on the kitchen, but that Baldor is calling me out to the shop.
Or did you mean the homemade stand?
