Merkava_4
There's no substitute for the red lube of love.
Now im interested, if i go into an auto parts store what am i actually looking for?
What's the viscosity of this Permatex red lube?
Also might give bar and chain oil a try... it'll stick to the parts.
If you want red ooze... just use ATF. Cheaper than the other stuff...
Merk,
What other lubes have you tried? Could you do a review, of sorts?
Doesn't Snappy recommend SuperLube (grease or spray) and have you tried it?
Any links to how to apply this stuff....drench or just dabble lightly on teeth (why so much run off?).
When I got home yesterday my girlfriend asked me what was in the bag, and I told her it was a new lube I wanted to try. She was pretty excited too...until she found out it was for machines.![]()
SuperLube 21030 is the official lube. It works good but it's a grease, so you have to take some time to paint it on the parts as opposed to just flooding the ratchet like you would with red lube.
LOL!!!![]()
Do they send different lubes depending on the style of ratchet mechanism?
I'm confused because when Williams sent me my rebuild kit for a B-52A it came with "Snap-on" ratchet oil (not grease). Do they send different lubes depending on the style of ratchet mechanism?
What color is the Lucas? If it's not red I may try some.
I'm confused how this permatex ultraslick stuff can be "sticky" "tacky" and really viscous, yet still leak out of the ratchet.
Is that course tooth or coarse tooth?
It really doesn't leak out, it gets pushed out by the rotation of the gear - but only the excess gets pushed out. With it being so tacky, what the gear needs stays on the gear. For a course tooth ratchet, it's the end all be all cure.
Edit!! - Is that course tooth or coarse tooth?![]()
And I believe it's 'coarse', but don't trust me, I'm a stupid foreigner...![]()
Thanks........I wasn't sure.![]()
Doesnt work well in the Cman 60 tooths for some reason, its amazing in Snappy dual 80's though!I think that sums it up very well.
I also tried it on a Cman pro 60 tooth and wasn't all that happy. Seems to viscous for fine teeth (at least at the current temperatures, it snowed last night here in Houston...)
I wouldnt use that icon in a thread talking about lubeBring it![]()
by the way, I've tried plain MINERAL OIL in ratchets, and as you might suspect, it's too thin.
After just 2 uses, it started getting loud again. I opened it up and it looked like it actually evaporated. I guess it all just leaked out.
I think the results may have something to do with how clean the parts are to start with as it doesn't seem to stick well if the parts aren't reasonably clean of old lube to start.
Hmm... I didn't try it in the Dual80s since my Cman 60 didn't like it either. Maybe the dual pawls don't bind even with a higher tooth count... Which size Dual80 did you try it on?
So, did you try the permatex in all three 80s? (T, F, and S)
Did it work in all three of them?
