ScaldedDog
Based on responses in another thread, I thought a little poll might be in order. Please let us know what kind (length, bulb count, brand and source) of T8 fixtures you have.
I too was wondering that Palmetto. Mine is grounded the same way, using the ground wire from the romex to the green screw in each fixture.
And to clarify mine, I have 4 eight foot fixtures that use 4 four foot bulbs....so essentially I only have 4 ballasts but the amount of bulbs is the same as 8 four foot fixtures. I have RFI interference and my radio is a cheaper plastic boombox. My lights are from Lowes and I am not sure if the ballast is residential or industrial.
I need to add a few fixtures in my garage and have been following this subject closely. I was in HD today and asked a friend of mine who works in the lighting department about the RFI interference issue. I don't know if it makes any difference, but he pointed out that there are two different ballast units for T8 bulbs. One is listed for residential use and the other states on the unit commercial use only. Makes me wonder if there is any possibility that one or the other ballast causes the RFI.
most anybody that is experiencing RFI noise has T8 electronic ballasts that have a high THD %, any spec grade product out there will have at least <20% THD ballast or better, heck the standard for most commercial Instant start T8 ballasts nowadays is <10% THD. People, don't buy the residential grade products at Home Depot/Lowes/etc.. and expect commercial grade ballasts, they only offer the offshore ballasts to keep their costs down.
*Always buy your lighting products at a wholesale electrical distributor and ask for better then residential grade ballasts, heck ask for <10% THD ballast in any fixture you buy.
I have 12 x 8ft 4lamp T8 with 1 ballast per fixture, <10% THD electronic ballasts and zero RFI issues.
Just checked my ballasts. They are Triads and are listed in their specs as being less than 10%THD. My AV stereo receiver (PIONEER) is not being used because thr RFI is very bad. Cheap boombox style radio is only slightly better. The receiver has had ant. moved outside and shielded cable used and the RFI didn't change. I even ran an extension cord from the house with no change. Originally there was the cheap t12 fixtures that can be purchased for $10.00 at Lowes in the garage with NO RFI noise and these were the China specials.
The Federal Communications Commission (FCC) in the USA lists equipment that may potentially cause radio/television interference under Part 15 of their rules (47CFR). There are two categories: Class A and Class B. Class A is less stringent, and is for business and non-residential applications. Class B is more strict, and is for residential applications. Your home computer for example must be listed under Part 15, Class B. I have not seen any electronic ballasts listed for Class B use (they may exist, I just have not seen one).
The rules state that you are responsible for any interference generated (so if your neighbors complain, ya gotta do something about it).
If you have a metal building, it may be shielding or greatly attenuating your radio receiver from most of the stations you listen to since they come from outside the metal shell. The lights however are inside the metal shell, and are not attenuated. If this is the specific problem you have, getting an outside antenna hooked up to your radio will greatly help the situation.
Grounding does not in itself reduce the interference. Sometimes it helps, sometimes it hurts, and sometimes it makes no difference. Shielding and filtering does help. The problem is in the ballast and/or bulbs themselves. Shielded fixtures are one solution. Powerline RFI filters at each fixture are another.
-- Tom
Hey Vicious, what did you find?
It does show that it is an "outdoor" type ballast and was likely made with little consideration to RFI reduction...
