1906 house. 5 BR. Will be a college rental. Anywhere from 5 to 9 tenants.
Gas furnace, water heater (for now)and dryer.
At inspection, (after accepted offer) had an electrician come through and make the following recommendation:
"The 100 amp main breaker in the electrical panel has been overheated (The oxidation seen on top of the main breaker in the attached photo shows the results), There is 1 double tapped 20amp breaker feeding 15 amp wire and 1 40 amp breaker feeding 30 amp wire.
We would remove the current 100 amp panel and install a new 100 amp 20 circuit Siemens panel with a main breaker. $685"
Would you do ^ this? or would you upgrade to 200 amp service?
I haven't received a quote yet for the 200amp change. Have a guy coming this weekend. what could I expect to pay for this? I think the mast on the side of the house would have to be changed in order to do this.
*Disclaimer.....I know nothing about electrical so hopefully i am using the correct terminology.
thats just spending extra money for no reason. Not sure what part of the country your from, in the philly area its usually around 1800-2500 for a 200 amp service change.
