BuickFarmer
What is standard for attaching the 2x12 truss carriers ie beams to the 6x6 poles. Will be using triple 2x6 laminated poles.
When I was first thinking of building a pole barn (post frame building), I did some research. I ended up purchasing the NFBA (National Frame Builders Association) design manual. As I recall the manual specified the use of 1/2" or larger bolts for the connections. The number and size of the bolts depended on the load being placed on the connection. Heavy loads required shear plates (such as http://www.portlandbolt.com/products/others/shearplates.html) in addition to the bolts.
Over the years I have looked at the building codes for various cities and counties around the country. Most require through bolts for connections, but some allow the use of lag bolts. My rural property is located in SW Indiana where there are no building code or permit requirements. The standard practice there is to use large nails (spikes) for connections.
If you are building in an area subject to building codes you should consult with the proper authorities. If not, you might want to talk with someone in a nearby area that is subject to building codes.
I never heard of these before, but I would certainly want them IF the posts were NOT notched.Heavy loads required shear plates (such as http://www.portlandbolt.com/products/others/shearplates.html) in addition to the bolts.
What is the spacing of the posts (typically 8'), span (width) of the trusses and what type of roof ? If you are only 30' wide and a metal roof, doubled 2x8 would probably good enough.[/I].
Thanks everybody. And sorry, I should have given more info. The building will be 40X40x12 with 5/12 trusses on 4 ft centers toe nailed and hurricane strapped to truss carrier . 29 gauge metal roofing. Poles will be on 10' centers. Truss carriers will be 2x12 yellow pine on each side of a triple 2x6 laminated pole. On the exterior, I plan to nail a 2X6 on each post between the bottom of each 2x12 and the top of the top most 2x4 girt to provide additional support for that 2x12 carrier. On the interior the space between the poles will be filled with 2x6 studs on 2 ft centers and then horizontal 2x6's nailed to them from the floor to the bottom of the interior truss carrier as the interior wall covering.
Pre-drill the post or the carrier on the ground with a guide. That way you know it will be square to the face of the board. Use a standard 1/2' twist drill, but slow down the speed.Any recommendations on the drill bit for drilling 8 inches through yellow pine
metal trusses or wood?
here's a good way to attach the trusses to your 2x12's. you put a 2x6 between the 2x12's and let it extend up next to the top of the truss........gives a lot more nailing surface than those awful hurricane clips.
also when you lay out your poles and trusses make sure every other truss sets on top of a post (you did say your trusses are 4'-0 on center). cut the post off flush with your 2x12's and lay a 2x6 on the flat to fasten the truss to.
At my last house I had stud walls and the inspector made me use those hurricane clips at every truss and he insisted that every hole had to have a nail, well thats a lot of nails in a small area and it looks good on paper but it has a tendenacy to split the bottom the truss and actually make it weaker. when i got done with it i thought what a mess, whats stronger about that?........anyway just thoughts.
Simpson makes more than a dozen different types of "hurricane" truss connectors (their "H" series). Obviously you have to go with what the engineers specified or what the inspector approves. Some have a lot of holes, some don't. Pretty much all of them accept the Simpson Strong-Drive SD
Structural-Connector screws. Yes, they cost more than nails, but they are easy and quick to install.
