Souped-Up Tools/Machinery: What have you done?
-Brent-
Utah
Some of us cannot leave well-enough alone. Others have a need to make things better to fit their needs, etc.
This is a thread I'd like to showcase that type of stuff.
For me, I'm small potatoes.
As I've posted elsewhere, I've reduced the speed of my 1935/36 Atlas/Craftsman bench-top drill press and outfitted a bench grinder with a Jacobs 33BA chuck.
An acquaintance I've got in Utah outfitted his drill press with an annular cutter to MT3.
So, what have you done? Post 'em up!
Packard V8
Spokane, WA
I usually bump up the horsepower on any machine I build and the electrics are all run on 220V. One of the 14" Delta DPs has a 3/4hp motor, the 14" Delta bandsaw has a 1hp, the pressure washer has an 8hp Wisconsin.
Unmarked Bill
Northeast Los Angeles
I will have to get some photos when I get back to the shop, but...
Did you use the threads on the grinder to put the chuck on or did you turn the shaft and press the chuck on?
-Brent-
Utah
I just threaded it on. The threads are 1/2-20. I found a chuck to match. They're cheap and plentiful.
countryroad82
Kentucky
I knock out the annoying guard thingy on the handles of my die grinders because I hate having to push up on the handle then down to actually use the tool. Does that count?
Grigg
Lexington, VA
Kubota single cylinder water cooled diesel engine for a Super Split wood splitter.
Stephenw
Utah
<iframe width="420" height="315" src="//www.youtube.com/embed/hznufmtxHAU" frameborder="0" allowfullscreen></iframe>
machine_punk
Napa Valley, California
I build a lot of new custom stuff, but I cannot think of a lot of things I've modified to make it better. Here's a couple of modifications to make things more like I want them:
I changed the center of my shop fan to something a little more inspiring:
View media item 22549
I wanted my portable bandsaw to be be a vertical bandsaw, so I built a bracket to hold it...
View media item 24133
View media item 24132
View media item 24131
Kev
retrobuilder
Alpharetta GA
nothing radical, Delta DP with much better German Rohm chucks and economy vertical digital scale for drilling depth control and a Mastercraft USA small cross slide for simple slotting and plastics prototypes and careful fitment of moving pulleys, lube + custom stand..Ive added additional gooseneck lamps to all the saws, sanders and such and a few "lemans stripes" to cabinets.. My router table and bandsaw all have Kreg micro adjust fences and fixturing miter slots plus safety paddle switches. What ever makes it work better for me.
techenthusiast
Put a quarter inch drive pin on a 1 inch drive impact gun... Just kidding
Provincial
Near Salem, OR
I have an older Hitachi 18V ni-cad cordless 1/2" drill. I have picked up a couple of 14V 3/8" versions, and discovered that these have a nub in the battery compartment that fits a corresponding groove in the 14V battery pack. By cutting off the nub with a sharp wood chisel, I can use the 18V batteries. I've been doing this for about four years now, and haven't had one problem. The 14V drills have a lot more power! The 3/8" drills have a faster spindle speed, which makes them better for smaller bits. I have standardized the battery packs this way.
Zeke
Back in the day... used a 9Volt battery in a 7.2Volt Makita cordless drill.
Richard
All the time. I still have 9v tools and a 7.2v angle grinder. No 7.2v batteries or charger left but the little grinder makes a hell of a nice drill bit sharpening tool out on the job. Just gotta wedge it in there as it sticks out and will easily fall out.
