Lost Road
I'm trying to get ahold of the guy, so I can go pick it up. Seems like it's a pretty good deal. What do you think?
http://slo.craigslist.org/for/4375421896.html
no, do not buy it. that is not a honda generator, it is a knock off.
It may have a real Honda engine, but I expect the generator plant is a fake and would likely not last very long under regular use.
There are 100’s of generator makes out there, but only a handful make the electrical panel. I believe Onan, Honeywell and a couple of others make the panel for all the other, including Honda. When you pay a premium for a generator, you are paying for the motor, Honda’s and other OHV’s carry the $$$.
If it isn’t far, go check it out. Putting a fake sticker on the side is one thing, but to fake the motor is difficult, or more work than it is worth for the money he can get. If the motor is legit, you should be good to go….although, you might think twice about doing business with someone if those stickers are knockoffs.
I need something reliable to charge my car battery and run my air compressor and tools at the races. I need to be able to run it for long periods of time. It has to be a good generator.
Honestly, I try to stay away from hf for motorized or power tools. I do use their aluminum floor jack and aluminum portable air tank.
Understood, just throwing it out there as a low cost option.
FWIW I wouldn't get within blast distance of an aluminum air tank, so we all pick and choose for different reasons![]()
lots of things i don't agree with. there 100's of makes out there but not hundreds of manufacturer's. a lot of them, including most of the imports do not have a panels made for them by reliable mfgs. like onan and honeywell.
i also disagree with the motor being the most important part. sure it needs to be reliable but putting a honda motor on a cheapass generator head does not make an outstanding generator. only a quality generator head will produce clean usable power.
i would rather have a cheap honda clone on good generator than a honda on a crappy generator head.
