Vapor barrier for ceiling necessary?
dschmit
Nebraska
I have a 38 x 52 stick frame bulding that is just geting finished. 2x6 wall construction with pro-rib metal on the outside walls and roof, soffit vent with a ridge vent. It has radiant floor heat & 2" closed cell spray foam on the walls. Interior of bulding is also going to be lined with metal including the ceiling. I want to blow in R-40 loose fiberglass on top of the ceiling tin. Do I want to install a vapor barrier above the ceiling tin in this appication? I do have a wash bay in there also if that maters.
sands35
St. Joseph, MI
The cellulose gets blow in after the ceiling is up. Still need a vapor barrier though. Stapled up sheet plastic works great.
Highbeam
Mt Rainier foothills, WA
Why so much desire to skip the ceiling poly? It is cheap and easy. Dont just do it for moisture migration, do it for air sealing to keep all the heated air from flowing out through the roof. Don't you guys close your windows when it is cold out? Thats not for moisture control, it's so you dont let all the heat out.
GYPSY400
Naughton Ontario
Yes, vapor barrier is needed.
X2! Anything other than spray foam requires vapour barrier.. Be sure to tape all seams and acoustic seal all wood joints.. The building will need to be sealed like a ziplock bag to be effective.
KenC
OK, I need an education. I always thought a vapor barrier was to prevent migration on interior moisture into the insulation. Some paints also function as a vapor barrier, to be used in retrofitting insulation in older contruction.
That said, since a metal ceiling is impervious to moisture migration, why is an additional barrier recommended? And what is the source of the recommendation?
Seems to me this is a situation where any moisture that may make it past the metal seams would wind up condensing between the metal and plastic.
Not arguing, just asking???
OccupantRJ
Eastern North Carolina
I am thinking like you are on this. I have no windows in my shop, and will be installing a metal ribbed ceiling with blown fiberglass insulation. I am trying to decide on whether to install a vapor barrier above the ceiling.
Rookie2
Western Pa.
This will freak you out ! I built a Morton bldg. metal walls inside & 4'x4' x1" fiberglass drop ceiling with 6" fiberglass on top. METAL ROOFS cause RAIN inside ! I've closed down the sofit vents ,i've opened 2'x2' vents on end walls plus 60' ridge vent. METAL ROOFS **** !
rburke65
Canfield, Ohio
I'm still believing that you first staple the plastic sheeting to the bottoms of the trusses or ceiling joists, install the metal liner, blow in or place your insulation.
dirttracker18
Slate River, ON
As already stated, the vapor barrier is not just to stop the migration of moisture, which your metal will NOT do. It stops the migration of air that is carrying your conditioned air away. All insulations, except closed cell foam, will allow air to travel through them. Hold up a batt of insulation between you and a blowing fan! Insulation attempts to stop the transfer of heat or cold, not air movement. The stopping of air movement is the just of the vapor barrier.
D
dschmit
Nebraska
Thanks for the replies. I will be installing a vapor barrier. Any opinions on 4 or 6 mil and is one easier to work with than the other on a 12.5' high ceiling?
danski0224
Near Naperville, IL
Use of a vapor barrier, placement of vapor barrier and the type of vapor barrier is dictated by climate zone.
You should really do your own research.
Walls: http://www.buildingscience.com/documents/reports/rr-0410-vapor-barriers-and-wall-design
Ceilings: http://www.buildingscience.com/documents/digests/bsd-102-understanding-attic-ventilation
johnlb
Iowa
I used a couple of large blue tarps. Cut strips of 2x4 and nailed them to the bottom or the trusses.
dirttracker18
Slate River, ON
It would have been cheaper and better to use real 6 mil poly for a vapor barrier. Tarps will disintegrate over time.
6 mil poly is very cheap and the correct material to use
johnlb
Iowa
The first one I did with a tarp was over 30 years ago and the tarp still looks like new. And it don't rip when putting up by myself. Just a dumb farm boy!!
johnlb
Iowa
I got my tarps at Menards. If I remember right they were 42'x64', two of them worked out perfect. (building is 120' x 40') Don't get to HF very often as the closest store is 120 miles one way....
rburke65
Canfield, Ohio
I'd use the 6 mil. The bigger the better...less seams. I made a "T" out of 2x4s, as a prop. Cut it the height of your ceiling plus ?? An inch. Use this to prop up the hanging plastic sheet to reduce the weight of the piece you are placing. Less rips..... Really el sane you are by yourself.
