Solid Rubber Wheel chocks - PASS.
http://www.harborfreight.com/solid-rubber-wheel-chock-96479.html
Sticky and robust. Heavy and durable, doesn't slip.
Shown here in use with Compac Jack #90535 and Esco stands:
Seems to have ALL 5 star reviews too.
nice video lol i made the 1st comment lol
Has anyone used one of these "drain tornado" gadgets? http://www.harborfreight.com/drain-tornado-96850.html
I've got to deal with a foundation drain that's plugged pretty solid with mud. Years of neglect, long story. I tried one of the "blow ball" tools (aka H-F Large Drain Cleaning Bladder but I paid 3x as much for one at H-D since it's closer) but all that did was pack the mud tighter until the bladder burst due to overpressure.
I may end up with a power snake (eel) in there to clean it, but saw the drain tornado and thought it might work since it doesn't push pressure like the bladder did (mud would wash out where the bladder held it in). At the same time, I'm leery to stick anything back in there that might come apart and end up not being able to get back out. I about crapped myself when that bladder burst, because I figured the rubber part was off the hose and left in the drain but I got lucky and it came back out in one piece.
Do they hold the car in place by generating a force field?
Coach
Coach
One way to attack your problem is to run a stiff garden hose or PVC pipe (equipped with a brass nozzle) up from the outlet (if accessible from the low end of the system) of the drain. As you push the hose in, the water is eating up the mud ahead, and the slurry is carried away by the flowing water.
Your problem with the first attempt is that the drain was so blocked that there was no where for the slurry to go, so it just backed up and raised the water pressure.
The one tool I ever bought from HF.
The Orange soldering gun. I don't know the part number but its the only one they sell. - FAIL
Lasted a week. And you can't buy replacement tips for it.
Bought the craftsman gun and have had it for 4 years and have used it heavily.
http://www.harborfreight.com/14-and-38-drive-x-14-38-double-head-flex-ratchet-wrench-67994.html
How is this? Does anybody else make one like this?
item 67994 1/4" and 3/8" Drive x 14-3/8" Double Head Flex Ratchet Wrench. paid $30 for it full price in store
at 1st, i was hesitant to drop 30 bucks on a hf ratchet. so i passed on it. the following week i counted a few times wher ei felt owning this tool may have saved time aggravation--mostly on tight fitting accessory belt tensioner locations. so i went back and bought it.
been using it for over a month now as needed with no complaints. i dont use it as a main ratchet or anything of that nature. mostly use it as a serp belt tool. so far so good.
pass so far and recommend for light duty use-- i.e. not to use as a breaker bar or a ratchet that you exert a ton of tq on. im sure there will be a day where i will have to abuse this tool and find it's weak spot.
From earlier in the thread.
I've also got on and am really pleased with it. Solid feeling tool.
EZ-Red makes a similar one. No experience with this one though.
http://www.thetoolwarehouse.net/p-32797-14-38-stick.aspx
Is there ever a coupon for it? How hard is it to warranty at HF.
IMG_20140513_210053_790 by wrfalcon75, on Flickr7 gal Aluminum Air Tank item#94801
http://www.harborfreight.com/7-gallon-aluminum-air-tank-94801.html
Pass with my modifications. Bought it with 25% off coupon the other week, didn't like the existing manifold and schrader valve only fill.
Added a 5 hole aluminum 1/4" manifold, used the existing gauge, added a 140psi pressure relief valve (same pressure as on original manifold, even though it's advertised as a 160psi tank), schrader valve fill in case I need to fill it at a gas station or such, and a female quick connect fitting. I doubled up male quick connect fittings on a valve so I could quickly fill it with my compressor, remove the adapter and use it for what I need. I'll probably replace the included hose with a short coiled hose and a better tire chuck.
Before:
http://www.harborfreight.com/media/...b33525d08d6e5fb8d27136e95/i/m/image_23185.jpg
After:
I like that idea, could you give a closer view of the manifold & connections? maybe from a few angles?
Any one have any experience with the 4-in-1 Jump Starter with air compressor?
http://www.harborfreight.com/4-in-1-jump-starter-with-air-compressor-69401.html I'm interested in light duty use for topping off auto tires and occasional jump starts.
I occasionally go off-road and air down my tires from 35ish to < 20 psi to get better traction. The first time I tried to pump it back up with a similar compressor, it was taking 10-15 mins to get a few lbs into the tire. At that rate it would have taken > 2 hours for all 4 tires. Plus the compressor gets pretty warm during that time. Plus not sure the battery would have lasted.I like that idea, could you give a closer view of the manifold & connections? maybe from a few angles?
I'll try to get those tonight. I'm thinking about drilling and tapping the manifold to permanently add the male quick connect and shutoff valve so I don't have to carry that adapter around.
IMG_20140515_210959_055 by wrfalcon75, on Flickr
IMG_20140515_210946_262 by wrfalcon75, on Flickr
IMG_20140515_210930_089 by wrfalcon75, on Flickr
IMG_20140515_210921_477 by wrfalcon75, on Flickr
