Fueler
I have 4 400w metal halide fixtures in my shop with surrounding areas supported by CFL tube fixtures.
I bought one of THESE to try in one of the MH fixture. I can't say that it's really any brighter and perhaps might be just a bit less than the MH bulbs that are a year old now. It's a tough call. I think I can live with it.
I contemplated leaving the light deflector off to give out more light but opted not to in order to keep the CFL from getting dirty.
The watts on the CFL is 180. Oh, and it really is big in size but it did fit in the canister with the light deflector closed.
No more slow ramp ups that is normal for MHs.
I did not measure the actual wattage and am assuming the mfg numbers are correct.
The cost of the CFL bulb was 109.99 plus shipping.
The bottom line is this.
At my current electric rate including taxes each MH running for 12 hours (often more) cost me $11.76 per month or $133.48 per yr.
The CFL for the same 12 hrs should cost me $5.27 pr month and 60.07 per yr.
The break even point at the current rate should be 1.5 yrs.
I have the home and half of the rest of the shop converted over to LED and really wanted to do that for these MH lights just because I like the daylight range possible with LEDs. However they are going to have to drop to $200 ea to make that anywhere close to financially sensible.
Update: Came back to check when it was dark:thirty. The CFL is definitely brighter than the yr old MH lights.
