non-scratching impact sockets
lewis
I’m looking at getting a pt job at a service station, and would most likely be a tire changer to start. I picked up an IR 231 used for $35, and need to get some sockets for it. Would I be ok using normal impact sockets, or should I get some special sockets with “wheel savers” or some sort of sleeve to protect the rim. I don’t know how much of the clientele have nice enough wheels to worry about this, but I want to be prepared.
If I do need special sockets, which brand should I get? All I’m finding online are sunex and central pneumatic “earthquake”, which is an HF brand.
Monte
Germany
autoace
Maine,USA
I have some protector sockets for the real nice cars/wheels, where clearance to the lugs is minimal. Most of the time the protector sockets won't be necessary. The shop will probably have torque sticks for wheel install anyway(the ones you don't put a socket on). Matco and Cornwell have real good impact sockets, but.......The Harbor Freight Earthquakes will be aok, for the money and durability. You can always lighten your wallet on truck tools later.:bounce:
rsanter
visalia ca
how about getting some good sockets and then installing a sleve or shrink tubing on them
bob
jerk_chicken
Germany
There was some company that made non-marring inserts one could place in any socket. Don't know where those went.
Leonard 95
The grey pneumatics I am using are working great, the 19mm and 21mm are very nice and well priced.
zuspiel
Houston, TX
Toptul also has a set w/o the sticks. 17, 19, and 21 for something like $23. The 13/16 is separate for $7. I put them on my wish list that I sent to Mike...
kartracer55
Do yourself a favor and buy a metric flip socket. SK is decent, I have one, but I prefer the truck brands. The reason being is that on the truck brands, the OD is smaller on the 19mm side than the 21mm side, where as on my SK and craftsmans, its the same diameter. Definitely works just fine though. I like flip sockets because they take the beating, not my regular impacts.
Don't sweat the torque sticks either, unless our boss requests you use them. Instead, figure out what setting on your gun gives you around 90ftlbs while on your shops line pressure.
Oh, and youll find that most customers with high end wheels usually have a special lug socket that goes with them anyway, at least if they really care.
Elroy
kentucky
And if the customer is Elroy he'll DEMAND that you use a torque WRENCH and not some damn stick.
senlow
Wheat Ridge, Colorado
I'm with Elroy on this one. Wheels are to be installed with a torque wrench. As far as I'm concerned, there is NO acceptable substitute.
Danglerb
SoCal
I have the HF set, I think Hazet makes them, works fine and about $25 for a set of 6.
kartracer55
So let me ask. Are you willing to pay for the extra time it hogs up a bay? Because I can assure you that the majority of dealerships will not be using a torque wrench, nor will the majority of repair shops unless you SPECIFICALLY ask and they agree to it
As a side note, I use a torque wrench on MY wheels on my own time. Thats besides the point though...
zuspiel
Houston, TX
Ok, my sanity is saved :D
They do look different than the Hazet ones (as far as one can tell...)
Thanks, rcleaver.
T56 Impala
Roswell GA
I have the 3 pc HF aluminum wheel sockets with the protective sleeve. They work just fine for ME. I have used them with my impact and torque wrench without any problems. Even on severely over tightened lugs. I think they were like $7.00 when I bought them.
Being aluminum I figured they would break, but they just keep on working, so I keep on using them! (I think the are aluminum? They are not black that's for sure. They are anodized gold, red and blue.)
