Socket set advice
coppermouse
I would like suggestions on my next socket set purchase.
I want to get a 1/4, 3/8, 1/2 set both metric and SAE.
Good quality sockets a good molded case with a compartment for extra extensions etc.. that wont let them roll around and mix up when I carry them (that was the problem with my old Craftsman set, it had a tray that went inside the case and they would always come loose).
And nice ratchets that have a fine ratchet ( the standard Craftsman is too coarse for me).
I am looking at a Allen 19222.
Any input would be appreciated!
autoace
Maine,USA
Well, seems you already have Craftsman, they are a good bang for the buck. I would recommend Cornwell master sets, but they are pricey. What's the price range? Allen are not bad, they are Danaher, try to stick with the USA Allen stuff. If you don't care about origin, Gearwrench makes some cased socket sets, and very good fine tooth ratchets. I'm not a big Asian tool fan, but the Gearwrench brand is very good. Some other members will probably post the Toptul option, they look to be of good quality, available in cases, fine tooth ratchets,etc....... Do some homework, and price comparison. Toptul is available here through wrenhandtools, he gives discounts to members. Good luck.:thumbup:
autoace
Maine,USA
C
coppermouse
Yea, I thought about doing that, I don't want one of those big drawer things, too big to lug around. I really want the molded case with a spot for each piece, do they sell them without the sockets
krusty the clown
Member Emeritus
niangua, mo
i know snap on does but you could get a whole set of GW'S for what the box cost:spit:
Tlag
Go with rails and a regular tool box. The blow molds get bulky fast if you have a lot of sockets. Blow molds always end up with tools that don't fit, or empty space. You can cut the rails to fit the sets.
PowderKeg
Little Rock, AR
...with all 3 sizes in one box
...I don't want one of those big drawer things, too big to lug around. I really want the molded case with a spot for each piece, do they sell them without the sockets
No offense intended, but this sorta sounds like a case of having the cake and eating it too. IF you want reasonably complete regular depth socket sets in all three drive sizes SAE and Metric, that's gonna add up to alot of sockets, which take up alotta room. Then throw in a decent selection of extensions, breakers, ratchets, etc., and allow a little room for extra additions down the road..... Well, you're gonna be blowin' out the hinges and latches on any reasonable sized blow-mold case in short order. And what about room for deepwells, specialty sockets, other accessories....
Now if you don't care about relatively complete sets, are willing to settle for mostly one socket hex size of whatever drive size it happens to be in, very limited drive tools and accessories, have little room for extras with no intentions to add much else anyway, and it'll spend most of its life sitting in the corner or the trunk, then a blow-mold one-case-fits-all set may be satisfactory. Personally, I've never been thrilled by those kinds of sets. Better to get a decent metal box with a tray, cut and jam in some plastic dividers if you want to separate some drive accessories, and put the sockets on rails (removing unused clips so you can see when a socket is missing). Or at least separate large blow-cases for each drive size, big enough to stick additional stuff in down the road.
When I was carting my tools back 'n forth to the pole yard, I had one metal box for 1/4 and 3/8 drive stuff, another for 1/2 and 3/4 (a danged heavy box that one), a third for wrenches, and a fourth for "the rest". Blow-molds may look nice and orderly at first, but IMHO longevity under regular use isn't very good and expansion room is almost non-existent.
Merkava_4
Clovis, CA.
Yeah.... I don't think I'd want 2 or 3 different drive sizes in one single blow molded case; it makes it too easy to pick up a 1/4 drive socket and try to put it on a 3/8 drive extension; I'd want a separate case for each drive size.
riley.m
Port Townsend Wa.
dont be too hasty in your purchase if wait a while and read these posts,i guarantee that you will end up making a better choice about what you buy.these guys know what they talking about.
Merkava_4
Clovis, CA.
It don't look too terribly bad, but where are those extensions supposed to go? I don't see a place for them. That's another problem with some of these socket sets in a case is that they don't give you enough different sizes of extensions.
Tlag
I have two blow molded cases for Craftsman. One is a 9-33876 with a 9-33875 tray. Its for a 140 pc Mechanics Tool set that you can have for $15 plus shipping.
I also have a smaller one, can't find a number on the case, but the tray is 33820. Also available for 15 plus shipping.
Both Made in the USA!:thumbup:
I tried to find some links, but they must be out of production. If you realy want them, I'll take a picture.
I out grew them and switched to metal boxes, using rails for sockets.
wrenchr
I have a standard and metric snap on 22pc sets in the blow molded cases for 3/8 drive and the 44pc 1/4 set. These sets cover most stuff I come across!!
91FE
Harleysville, PA
You stick your finger in the hole under the lid and that cover pops off.
PowderKeg
Little Rock, AR
Those ratchets look like the ultra-crappy basic round heads that are loathed by anyone unfortunate enough to pick them up. Extension selection is the absolute minimum, and it looks like they bounce around in the storage section (right along with the replacement higher quality ratchets that might not fit in the existing ****-ratchet cutouts). 1/4" socket selection looks good, 3/8" fair to good (there are more deepwells than regulars), 1/2" almost a joke.
Not trying to rain on anyone's parade - Allen quality is right on par with Craftsman (as they're almost certainly both coming off the same production lines) and a worthwhile brand that will give good service. Well, everything except those craptastic ratchets, they **** no matter whose name is engraved on them. :spit:
Does look nice and orderly though - at least until you start jamming in all the missing and extra tools to fill out the sets/cover more range. Of course then the additional tools won't be bouncing around the over-stuffed storage section - not until the top pops off while opening the case and a cascade of loose tools hits the ground running....
Merkava_4
Clovis, CA.
Yeah.... I don't think I'd like that compartment in the lid; that means you'd have to leave it open all the time as you work and in doing so, would take up a lot of space.
I hate to say it, but the nicest laid out blow molded case socket set are by snap-on; they just seem to have the right selection of tools in each case.
jerk_chicken
Germany
I had that exact case as a Craftsman set of that exact configuration in 97. The box came apart at those lame hinges after about a year and it was a constant struggle to carry it. Several times I was carrying it and it separated at the hinges, spilling my parts all over.
zuspiel
Houston, TX
I have one of those Cman boxes and use it for screws, rivets, etc. It's decent but I wouldn't want to have to open and close the drawers all the time. Don't think it would hold up. It's pretty light when empty, though...
posaune
Collinsville, Connecticut
I have an older one with three drawers instead of four. I used it for five or six years as my primary box and it held up perfectly well. It is now sitting on a rollaway holding multimeters and such.
My biggest problem with it is that it was *really* heavy when full of tools. It started to get too hard to lift out of the trunk of the car. I can't imagine it with another drawer.
The other issue is that it has the same locking style as so many non-portable boxes. That is fine as long as the box is kept right side up. If it tips and you get something lodged in the back or the bottom, it can be a pain.
Overall though, I wouldn't think twice about using it again if I needed portability.
MikeBrally
Resurrecting a really old thread here, as part of an attempt to locate a Craftsman #33876 tool case with #33875 tray. I sent a private message to Tlag (who said he had one years ago), but have not heard back. Anyone know if Tlag is still posting on here?
Cap'nJake
Mid-MO
Gearwrench makes really complete master sets of 1/4, 3/8, and 1/2. I bought them all and got the 120xp ratchets with them. They work really well. Been using them in an industrial setting for about 6 months now. Also the price isn't a killer.:D
MikeBrally
Thanks for all the input. I like Craftsman and wanted an all metric tool set to keep in my hobby car. Just purchased a Craftsman #33941 140 piece metric mechanic's set off ebay. Was really hoping I could find one of the #33876 cases to store these tools in. There are none listed on ebay. Anybody have a suggestion on where else to search?
If I cannot find the case, I will buy rails for the sockets and something to keep the wrenches, nut drivers, etc. separated. I do have a Craftsman 23" portable box which I think is big enough, but it isn't designed to hold this many tools in an organized fashion.
espyking83,
Those Westling Machine socket holders are works of art! I may have to get some of those.
oldldh,
That Dewalt set has a great price, but I believe it contains both standard and metric tools. I've been looking for a metric only set, and have found there aren't many out there.
theoldwizard1
SE MI
Getting a blow mold case with space for "extras" (extensions, universals, etc) is next to impossible. I gave up on that a long time ago. I just use rails for the 3/8 and 1/2 drive sockets. The ratchets, breaker bars and "accessories" go in the top of my tool chest along with the sockets.
