This really is an inspiration. I enjoy photography, architecture, metal and wood working as well as auto repair and paint and body work, so seeing all this has really lit a fire under me to hone some skills and try to make something remarkable.
Thanks. I am always looking to learn something new but every once in a while I come across something like the loft railing in the house where I do a little machining, welding and woodwork and I step back and think - wow, that's really cool.
______________________________________
Then there are the days that I've had recently where I wonder what the hell I'm doing and when will it end. Suffice it to say that the length of time this has dragged on and the financial toll has stressed the home life. Of course it's a bit like saying you don't like sailing anymore once you're in the middle of the ocean. I have no choice but to keep paddling.
Some of it is my tendency to figure something out and then immediately try something harder or different. It's been a boon in my creative career and a thorn in my remodel. Case in point is the 3mm solid edge band I'm working with. Glue was too tedious and so I am trying FastCap Speed Tape. It's funny stuff as it's crazy sticky and you really need to trim any excess before you place the trim or it's a nightmare to get off once the paper is gone. I use a knife to slice just the glue...
And then peel up the release paper with the excess glue on it. To aid in this I lay the tape flush with one side.
I then stick the edge band on just slightly proud to trim with the MFK 700 trim router. I learned a lesson with the doors which is to trim each piece as soon as it's applied or the tall edges interfere with the remaining sides. It's just a lot more complicated than edge tape.
That little gap is the thing I'm running into with the thick edge band. The Fast cap tape holds the edging well but not super tight. It can have a tendency to pull up so I am also pinning it at angles (like making an X with the pins) to help hold it. That's working.
I'm not about to go and remake things at this point so I'm working on fixes. Or trying to.
I'm using a piece of trim to scrape up the waxy filler...
Then a cloth to buff it in...
Then fine steel wool to remove the gloss of the buffed wax.
Then I coated it with poly today. My goal is to try to have some noticeable things done for when Judiaann gets back from her next trip. Which marks the start of mine. We have literally spent this whole month crossing at the airport and it's getting old.
But, I did get back up on the horse and manage some house work, some bike work and some blog work. Now I'm off to do some zzz work.
Gregor
