The official GJ ratchet lube poll...
What ratchet lube do you use/prefer?
  • Permatex engine assembly lube (red lube of love)
    Votes: 36 18.8%
  • Marvel Mystery oil
    Votes: 14 7.3%
  • Lucas oil treatment
    Votes: 6 3.1%
  • Super Lube (Snap-On)
    Votes: 81 42.2%
  • Motor oil
    Votes: 11 5.7%
  • Gear oil
    Votes: 5 2.6%
  • ATF
    Votes: 7 3.6%
  • Grease
    Votes: 29 15.1%
  • WD-40, PB Blaster, Deep Creep, Kroil (penetrating oil)
    Votes: 8 4.2%
  • Other: please specify (gun oil, white lithium, anti-sieze, chain lube, air tool oil, lubriplate)
    Votes: 29 15.1%
  • Total voters
    192
bareass172
N'awlins
Just for fun, I was reading on this the other day just to see what people were using. I searched and didn't see a poll, so for fun I decided to set one up. I think I covered the most mentioned lubes, but I can always modify/add up to 10 total if I've missed anything.
Edit: for those mentioning different types for different ratchets, the poll is set so you can choose more than one. I figured that was a better option than starting a different poll for each size/brand/make of ratchet. ;)
I, personally, have used Amsoil synthetic marine grease for years. I use a small brush to just coat the parts, not glob anything in there and cause problems. The marine grade sticks really well and doesn't tend to dry out too fast. It's amazing how much a very light coating will quiet down a ratchet while still maintaining complete function.
jim1987
Definitely need to add "whatever is laying around" for me its either 10w-40, 90w gear oil, or chain lube or chain saws. Depends if its higher or lower tooth count.
monomach
Illinois
It's not Snap-On Super Lube. Snap-on just happens to use it in some ratchets. You can buy the stuff at Harbor Freight or a hundred other places.
For ratchets that perform better with grease, I use Super Lube. For ratchets that perform better with oil, I use Marvel Mystery Oil. For old rusty garage sale pressed heads, I soak in whatever ATF I have sitting around.
jafco
Depends on what ratchet. I have a little 1/4 inch drive Facom ratchet that will not work with with any kind of grease or thick oil. I use air tool oil for that one. For most of the other ones I have been using Permatex brake caliper lube.
shopboy13
NY
Fluid film. Just don't try and use it until it has a minute to tack up or else it will come running out.
rtole
I buy super lube at ace hardware. They also have it in spray can, that works better for fine tooth ratchets. It is the BOMB for your toolbox slides as well!
n8n
Curtis Bay, MD
I recently cleaned and lubed some old Williams ratchets and used some Redline Heavy Shockproof gear oil. That stuff sticks to everything! held a Mason jar underneath the ratchet mechanisms while I drizzled the gear oil into them; soap and water wouldn't remove the stuff, I had to use Brakleen to get it all out.
Stooge
South Shore, MA
for lower tooth count ratchets, i use GN assembly paste and makes them feel pretty smooth, higher tooth count ones, i use LPS lubricant that comes in a windex looking squirt bottle
Cameronl
Connecticut
I first learned about lubing ratchets here on GJ. At the time all the talk was of RLoL. So I bought a small bottle at the parts store. It will last me a lifetime (maybe. I'm now actually assembling my very first car engine and putting it to use).
Mr.Nutcase
USA
depends on the ratchet,Matco 88 calls for Marvel Mystery oil
Snap on uses Super Lube
cheechi
Triad, NC
I have always used 3-in-1. Ever since reading GJ I have been using RLL & Marvel's also. No negative effects with any of these 3. Bigger heads, I think I like the RLL most. most of my 1/4 & 3/8 still have 3-in-1 without need to open it back up for a long while.
woody 73
The Great State Up North
I have used everything you name it...even bear grease:lol_hitti
The red engine stuff leaks for years not days, not weeks but forever:wtf:
The white lithium is my curse darn stuff turns into a rock.:(
What I have found the best is the super lube from HF:beer:
It depends: A coarse tooth ratchet (Proto, et all) does fine with a light coating of a grease, I used to use a light gun grease lately it's been Red Mobile 1 grease.
Fine tooth ratchets don't generally like ANY class of grease, so an oil, but I haven't settled on a particular brand/grade. Something sticky like way oil might be a good choice, many light oils just drain out and make a mess. I probably need to go try super lube...
nicksnothereman
In the Mojave
There are other people using marvel...I don't feel special anymore.
That's some good stuff, tends to last a while.
Wait wait I got a good one here...does that snap on lube come with the bill? Hahahahahahaha.
91bronc300
I think I've only ever used ATF and bearing grease. Next time I lube a ratchet though I'm going to try dry graphite powder.
newchris
CT
i typically will brush the gear with this anti corrosion high temp grease that we have in the shop to lube the rollers on school bus air brakes. almost got my friend to eat it once...looks just like peanut butter
bobcatdan
Kaukauna,WI
I find fluid flim works great for ratchet lube. Then again I use it for evverthing. Hey fluid film, if you are reading this, I'd make a great paid spokesman!
shopboy13
NY
Me too. I just found it about a year ago and oh boy that stuff is my favorite now. Don't remember the last time I've bought wd40
Adam.C
I'm not sure what others think, but I think the grease goes not on the gear teeth, but rather between the gear and the ratchet body. The goal is to reduce friction, preventing premature wear and gear material from clogging gear teeth.
Grease in the gear can limit tooth engagement, increasing pressure, and inevitably prematurely wearing the ratchet.
So I'm not sure what problem people are trying to solve with ratchet lubes. I could see soaking a ratchet in ATF just to prevent corrosion.
Kev442
Wi
I tried RLL, kinda sticky. Today I was wrenching, so the ratchets got hit with kroil as the can was right there. Even after, the cheap 1/4 drive is pretty much junk, time to buy a couple more ratchets.
twertsy
Reedville, VA
Other: Just because saying it in the other 22 threads on this topic apparently isn't enough............
Jure
Croatia
Kroon
and stihl grease for coarse tooth ratchets
Greasymofo
dallas
Ive used 3 in 1 sae 20 before works fine. But id say a dry loob like people use for bike chains. Its got a wax that sticks and dosent attract dirt. Or perhaps remoil with teflon would work good. To each his own. No ratchet needs oil or grease. But i guess they might appreciate the gesture.
Jason280
Depends on the ratchet....I have close to 100 or more floating around the shop, so I use a variety of different lubes. Lately, though, I have been using Pennzoil Syncromesh and SuperLube more than anything. Never tried engine assembly lube, but may give it a try since I have a can sitting on the shelf.
