My 2-car garage makeover.
Esoteric
Columbus, OH
My house was built 9 years ago, and unfortunately the garage has been a neglected area as it is in many homes. I finally decided that it was time to do something about it, and I started on the project late in December. It was originally supposed to be a “2 week” project, but that quickly turned into 6. I decided that if I'm going to do it, it's going to be done correctly, and done just once.
I do high-end detailing and paint restoration services on the weekends out of my garage, and therefore need a good working environment. This year I am taking my detailing to a whole new level (website in the works as well), and I knew that I needed a much more professional look for when my customers bring their prized possessions to me. A clean and well organized work space is equally as important.
After much thought, I came up with the following list of needs:
Insulated wall and garage door
Finished wall
Garage heater
More electrical outlets
Storage space
Organization
Better lighting
First up was to address electrical needs. I installed 7 new outlets on 2 new circuits...one of them being a 240v outlet for a new garage heater. Several of the outlets needed to be on the ceiling so that I could hang a few more fluorescent fixtures. For the lighting, I went with 3, 48”, 4-bulb T-5 high output light fixtures with 5000K bulbs. These are very bright, and produce a color very similar to sunlight. 57,000 lumens in a 400sq/ft garage...! Wear your sunglasses kids.
Now that the electrical was done, I was able to install my new Dimplex DGWH4031 garage heater. It's a 240v, 13,000 BTU unit that's perfect for heating a 400sq/ft garage. Even when it's single digits outside, I can easily heat up my garage to 65 or 70 degrees! And now that it's all insulated, it's not difficult to maintain a comfortable temperature while I'm working out there.
I knew I needed some nice cabinets, but some of the garage-specific models were just too much. I found some really nice ones at IKEA, and they only cost me $70/each. I placed 3 of them on the far wall for my detailing supplies, and put 2 of them near the entrance of the house for food and kitchen overstock (this helped with the wife-acceptance factor).
For the trim paint (part of ceiling, workbench, steps, door), I took one of the cabinet doors to Lowe's and had them color match the dark grey. Now everything is properly color-matched throughout the garage!
I still have to work on the floor, but it's simply too cold right now for any kind of finishing. That will be a good project for late spring.
I got a bit camera happy, so don't mind all of the photos. Enjoy!
It was exceptionally messy here because I had extra clutter from Christmas decorations. As you can see though, the wall was less than impressive:
Unfinished ceiling as well:
Workbench is a bit cluttered:
In process. As you can see, I have a support pole on the wall that barely stuck out further than the studs, so I couldn't just cover it with drywall. Later in the photos I'll show you how I addressed this.
As you can see from this photo that I took last year while working on this Audi, the side wall added some great reflections of clutter! Cool photo, but not very professional by any means.
The ceiling is already painted, and new T-5 lights installed:
Here is it mostly finished. I still have some decorating to do, and a few more bins of “stuff” to put on shelves, but it's pretty much ready.
Notice the vertical red stripe on the left. I bought an 8” board, sanded and painted it, and used it to cover up the support pole shown earlier. It was a great solution, and added a nice design element as well.
The red area with dark grey trim that goes up from the floor, and across the ceiling was a boxed-in section that was raised about 3” from the surface. It was a great canvas for me to work with and add some color and dimension.
You can see here where that raised area meets up with a lowered face to the ceiling. Once again...another opportunity to mix up some colors on different surfaces.
I've yet to finish the top of the workbench:
To the bottom left you can see a hole in the wall with cable coming out of it. I'm going to get an access box like you find on the outside of the house and finish this off. I just haven't gotten that far yet.
IKEA 24x30 cabinets.
Here you can see where/how I ran the outlets for two of the light fixtures:
Here's an example of my OCD, err I mean my attention to detail. I took apart my weather gauges and painted the assembly to match the rest of the garage.
The Dimplex heater is awesome! Small, compact, and puts out a lot of heat!
I tried to get the colors to flow from one side of the garage...from the floor, across one way in red, to another direction in grey, and then back down to the floor on the other side of the garage in red.
Thanks for checking it out!
E
Esoteric
Columbus, OH
Chris...thanks. Once the surface temp can be kept up (in a few months), I can do the floor properly.
cyclopsblown34...Thanks. I post a lot of my work on Autopia under TSC17 (Esoteric Auto Detail).
E
Esoteric
Columbus, OH
I almost forgot....Nice OHIO St. color scheme
Although I am a huge Buckeye fan, these aren't actually the colors, or the intended scheme. Red has always been my favorite color, and the dark grey was the best cabinet color they had that would look proper in a garage. But I guess it's convenient that it ended up that way though since both my wife and I attended OSU.
mmhouse
Desert Southwest
Wow....that looks fantastic!! Very, very nice job. :beer:
Where did you get your light fixtures? How cold does your garage get? At what temperature will the T5's have trouble starting?
Now to aggravate your OCD...are you aware you can get powder coated garage door hardware (i.e. track)? :lol:
E
Esoteric
Columbus, OH
Thank you!
Light fixtures from here: http://www.electricalmarketplace.co...escent-High-Bay-Lamps-Included-P1307C227.aspx
Without the heater on, the garage only gets down to about 40 degrees now that I have it fully insulated. The min start temp of these lights is -22, so I think I'm going to be good...it was a big selling point as well.
Please don't aggravate my OCD issues any more... :)
E
Esoteric
Columbus, OH
what happened to all the stuff?
Much of it got "purged". A lot of the stuff you see in boxes and containers is Xmas decorations that are now stored away. Some I found storage places in the house. Some is not pictured (mower, wheel barrow, etc).
E
Esoteric
Columbus, OH
It was almost 50 out yesterday, so I did a quick wash and snapped a few photos to check out the reflections of the new work:
Same shot, but with the lights on, and a different exposure:
Monte406SS
TL Type S, nice!
My purchased my wife the straight TL in 07. Great car to drive.
Garage looks awesome.
mmhouse
Desert Southwest
A couple more quick questions on your lights.....
1. The specs say they are for 'high bay' applications. Are there downsides to mounting them on a lower ceiling (mine is 10' and yours doesn't look much higher than that)?
2. It appears they are meant to be chain mounted but I see at least one of your lights is flush mounted to the drywall ceiling. Was this an option in the mounting instructions provided with the lights?
E
Esoteric
Columbus, OH
I think that the high bays have better light dispersion when mounted higher, but quite frankly I'm not running into any issues myself. The light is quite intense, which is great for the kind of work I do out there.
They can be either chain mounted or direct mounted. It comes with a chain kit in the box. They also have a variety of knockouts in the frame so you have a lot of flexibility on where you wire them. On the hanging ones I installed plugs on them, and the other one I hard wired it.
E
Esoteric
Columbus, OH
OK...here are a few:
98 M3
1000HP Viper
Mustang Before
After
Audi Before
After
A nice 50/50 shot:
68 Porsche before
and after
And the list goes on and on...
ColoradoBob
The garage looks great. Amazing how a little color and texture improves the overall look of the garage.
E
Esoteric
Columbus, OH
It's all about getting a perfectly level surface to get maximum light reflection. The "normal" time amount spent machine polishing is about 10 hours.
AgentZ
Christchurch, New Zealand
I think you really really need to write up a tutorial or tell us where to learn! Those cars are amazing!
Tools
what polishs and stuff you use
How to fix it when you get fish hooks and stuff!
Would love to make my cars look like that!
E
Esoteric
Columbus, OH
Tools
Thanks! You should see the look on the clients' faces when they pick up their cars. :bowdown:
I'm not sure this forum would want me to do that, but there are plenty of boards out there that do just that. Check out the writeup I did on the Porsche 912.
Jpfreak33
Brunswick Hills, OH
Great work!!! I might have to bring my wifes car done so you can work some magic on it. Cant wait till you get your site up and running, I am sure there will be a lot more before and after pics on there. Any more shots of the Viper? Was it a Hennessy?
E
Esoteric
Columbus, OH
Thanks!
I should have the website done by mid next week at the latest. There will be a full gallery of a bunch of cars on there.
It was a custom built motor, not a Hennessy. Major engine mods topped with a 300 shot of nitrous. Woohoooo. A complete writeup about the car can be found HERE.
Jpfreak33
Brunswick Hills, OH
Thanks!
You do amazing work, that is for sure. How far are you booked out?? I am sure if people see your work they would be lining up!! If my wife leaves for Iraq in Aug as scheduled I will be contacting you to give her car a once over before she gets back.
Your documenting is fantastic, a very fun thread to read, I need a drool guard for my keyboard :beer:
JMURiz
NoVA
I figured he was English (english flag) guess he just likes the colors.
GREAT looking upgrade and great polishing jobs, I'm a lurker on autopia, still waiting for my space to be done to practice on my old car.
E
Esoteric
Columbus, OH
Thanks for the very kind comments! Work is booking up already even though the weather is ****. I'm sure I'll keep pretty busy over the summer.
That would be a great thing to do for your wife. Please let me know how I can help.
Todd
Craig Balzer
Colorado Springs
Esoteric
Allow me to ask the crass question: What is the going price for a detil job like this? 10 hours of time // material // R&R of bits and pieces . . .
And can you reccommed someone in Colorado Springs who can match your skills?
Craig
1971 Jaguar XKE V12 -- pale yellow
1972 Jaguar XKE V12 -- primer
E
Esoteric
Columbus, OH
Esoteric
Craig
Craig,
It varies quite a bit depending on the area, and the level of detailers in that area. Having said that though, you can expect a $40-$75/hour range with the "average" being more in the 50-60/hour range. A word of caution though, beware of the Craigslist type of guy advertising a "high speed buffer" job for $99. Skilled detailers regular fix this type of work.
Let me look around, as I may be able to find somebody for you in that area. I'll be in touch.
Todd
E
Esoteric
Columbus, OH
Esoteric
Craig
Craig,
Unfortunately I'm not having much luck finding any of the top-level guys out in the CS area...
cyclopsblown34
Russellville, Missouri
Thanks to Esoteric joining here, I started lurking on Autopia.org again. Anybody interested in detailing should join there and check it out. You'll be lost for hours. more detailing info than could ever fit in a book.
