niferous
At my shop we have to pump grease into centrifugal pumps that we've rebuilt and it's usually a large amount. We've got a large air compressor and we can get the grease in a 55 gallon drum. My initial thought was to just use a 1" double diaphragm pump to just pump the grease into the pumps but I'm nut sure if that's going to work. We sell the double diaphragm pumps as well so we have one we can use and plenty of hose and fittings.
Right now we're just using lever operated grease guns and it's taking upwards to 70 pumps per grease fitting, 2 fittings per pump, and 4-5 pumps per day. Would it be as simple as plumbing a reduced 3/8" line into the outlet side of the pump with a bushing and then having a ball valve on the end of the line to control the flow? After the ball valve just use a regular 3/8" grease hose to apply the grease.
Does anyone see a better or cheaper way to do this?
