Water heaters Temperature and Pressure (T&P) relief valves are piped into the drain system.
Isn't that by code ?
Temperature and pressure (T&P) relief valves used on residential water heaters are typically designed and manufactured to relieve on pressure at 150 psig and on temperature at 210 degrees F. These ASME, ANSI and CSA (AGA) approved relief valves protect the water heater from excess pressures and temperatures by discharging water.
Where does a person drain the boiling water after cooking pasta ? I guess out the kitchen window. lol
