Penetration....
Junkman
Northeastern CT
What do you use for penetrating oil? I came across this product today in a friends shop, and it seemed to work well. In fact, it seems to work better than anything that I have used in the past. It might even be better than PB Blaster... Anyone ever hear of Max Professional Super Penetrate?????
Bull
Damn, there are so many of these products, most of which I have never heard of.
What did this one do that impressed you, Junk?
goodfellow
NoVA
There was an article about a year ago in "Machinist's Workshop" magazine that did an excellent and fair comparison of penetrating lubricants. The best commercial product was Kroil, followed by PB-Blaster.
However, the article also mentioned that steering pump fluid mixed with a small amount of acetone (don't remember the exact ratio) was as effective as Kroil and PB-Blaster.
Maybe someone remembers the exact article and can post the particulars. If not, I'll try to find the info when I get back home this weekend.
J
Junkman
Northeastern CT
Sprayed it on some very rusty bolts, and a few minutes they came off like slicing butter with a warm knife. This mechanic also told me that if you heat the bolt, and give it a spray, when you get the nut off, the threads will still be wet with lubricant.
jay50
I'm still looking for something a little bit stronger.
I want to be able to spray it on a rusted bolt and come back in 10 minutes and the bolt disappears completely; nothing but a hole when the bolt used to be....:lol_hitti:beer:
bgott
Houston, TX.
Well, I have had 2 cans of PB floating around for a while and then I found 10 cans of Aerokroil at the flea market for 2 bucks a can, when I've went through all that I'll give the Max a try!:thumbup:
ghostflamed66
centerville, Ia
I use kroil.
Here is what i did to sho my son how well it works, he uses pb.
I will take and put a drop of kroil and a drop of pb on my countertop. Then get 2 old 3/8x1 inch bolts and just stand one into each drop of fluid, with threads down.
5 min later the kroil has worked its way up all threads,clear to the bolt head.
The pb only went 1/4 to 1/2 way and never went further.
I still think pb is a good product, but kroil is much faster and will travel further.
Just my 2 cents.
Wes
Tom2
Yea really...Ive heard enough testimony! Where do I buy this product? How many easy payments? ;)
bluesman2a
Atlanta, Ga.
That's not penetrating oil. That's what is commonly referred to in the industry as "acid" :lol_hitti:beer:
rickairmedic
louisville ,Ky
Junk you know I was afraid to open this thread at first :D. I use Kroil and PB blaster predomintantly. I get my Kroil from a buddy who works for the local utility company most of the time :D.
Rick
sberry
Brethren, Michigan
I have been using the stuff at Walmart, 1.37 a can. I like Kroil but they cheapen the can. 10$ a can, I use a dozen or more a year, it adds up. We use it some for disassembly like most do but a lot for installation, I never put a bolt in dry.
a3tripod
In a pinch I've used a little diesel fuel. It penetrates rust much more effectively thatn one might guess. Granted I haven't performed highly sophisticated tests like the one mentioned above (Kroil vs PB), but it works.
porschedude996TT
Santa Maria, California
I know the product! It is called "Plazma-Torch" brought to you by the same people that make "Dog-****-Be-Gone". Just spray it on and it is gone in minutes.:lol_hitti
Sorry, couldn't resist...
51pontiac
I have used Kroil and others but found a local product called Nut Cracker that works extremely well. It stinks and the smell sticks around in the shop for a while but it works very well.
george4
N California
"The April/May 2007 edition of Machinist's Workshop did a test of penetrating oils where they measured the force required to loosen rusty test devices. Buy the issue if you want to see how they did the test. The results reported were interesting. The lower the number of pounds the better. Mighty interesting results for simple acetone and ****** fluid!
Penetrating oil . Average load .. Price per fluid ounce
None ................. 516 pounds .
WD-40 .............. 238 pounds .. $0.25
PB Blaster ......... 214 pounds .. $0.35
Liquid Wrench ... 127 pounds .. $0.21
Kano Kroil ........ 106 pounds .. $0.75
ATF-Acetone mix.. 53 pounds .. $0.10
The ATF-Acetone mix was a 50/50 mix (1 to 1 ratio)."
greenlion
For really stubborn bolts I use a product called "Plasma" also. Spray it on and the bolt drips out bottom. Wear shirts with sleeves! LOL
Tarheelgarage
NC
I've been using CRC Freeze-OFF lately. It is advertised as dropping the temperature of the bolt when sprayed.
I like it better that PB Blaster. I haven't seen Kroil in any of the store around here.
goodfellow
NoVA
That's the article -- thank you!! However, there was some confusion. The author said ATF-Acetone mix -- but in reality it was power steering fluid. In fact, the picture in the magazine which displayed all the products actually shows a bottle of power steering fluid -- not ATF.
Not sure if the properties of ATF are much different than power steering fluid -- but the author did make a distinction.
ahaidet
Akron, Ohio
Power Steering/Acetone mix sounds like the "hot setup".. however application of it could be tricky in hard to reach spots which got me thinking... and I found these...
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=1102
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=65297
I know that there is the sure shot brand but its 4 times the cost..
http://www.sureshotsprayer.com/default.htm
http://www.superkleendirect.com/steelsprayersmodela.aspx
I know this brings up the HF quality question and that whole can of worms..:wtf:
Do you think there would be any problem spraying the 50/50 mix of acetone and PS fluid out of one of these either brand?? Has anyone used the HF unit with good results for spraying anything?
How about one of those sprayers made for fertilizers and weed killers?
How did they apply it in the original Machinist Workshop article?
J
Junkman
Northeastern CT
Move to New England....... it is called road salt. :lol_hitti
Mattlt
MN
I'll throw my two cents in for ATF / mineral spirits. It's a good cheap mix for soaking stuck cylinders.
Several years ago, there was a product out there called Knocker-Loose. Haven't looked for it lately; not sure if it's still made.
Brad54
Why not a pump/trigger bottle? The manual spray bottles that you can get WD40 in.
So what's the final decision: ATF/Acetone, or Power Steering Fluid/Acetone? By this summer I will be taking apart a Duster and a '54 Buick, and will surely run across more than a few stubborn nuts and bolts.
-Brad
Oh, and in reference to the headline on this thread: There are two things in life where penetration is of the utmost importance: Welding is the other one.
nickdup1
Atlanta, GA
I've noticed that too, they do cheapen the can too much, but it's good stuff regardless.
Frank Elson
Lancashire, UK
I guess I've used more than half a dozen or more different penetrating sprays over the years.
Never found one that didn't work...
ahaidet
Akron, Ohio
Only problem I might foresee with that is Acetone has an affinity for eating plastic...
I remembered later last night that when I was working at the FSAE machine shop in college we used to put acetone in acetone safe spray bottles...
McMaster carries them and I bet Grainger/MSC do as well.
http://www.mcmaster.com/#catalog/115/1679/=kkx93
That link takes you to the squeeze bottle type which I had experience with for acetone and they show acetone safe ones...
If you page forward a little in the catalog they show the spray type... none of those mention acetone safeness though... so I guess use at your own risk...
Could just try the WD40 sprayers if they are cheap enough don't remember how much they cost off hand... but I think I will pick up a few of the Acetone ones myself.
zrxrider
I like PB but is stinks. Don't use it in the house. :lol_hitti Plus its easy to get.
limeranger
Bayswater NB, Canada
At work we use a product everyone refers to as winter green oil, It comes in glass bottles with a name that is about 6 miles long and no way to pronounce it. It can be put in some types of special plastic, which is what we do. It smells like peppermints but is really not supposed to be breathed in any amount. It works amazing, stilll trying to find out where to buy it though. bolts a 1 inch impact won't move will come of easily with a wrench after a very short soak, couple of minutes.
gofastman
Minnesota
Royal Purple MaxFilm
best stuff I have ever used! smells the best too, I havent tried Kroil, but I have used everything else mentioned in this thread.
Expencive but worth it, I found it at Oriley's and some NAPA stores.
