upgrading old drill press?
danielbuck
I have my father's old 3 speed bench-top drill press. It's been working ok for me over the passed few years, it still manages to put holes in things :D It's a "King Power International" model K-6 with a 1/4hp motor. It was originally purchased from Lowes in 1985 (I still have the receipt, haha!). So I imagine it's probably just like any other imported 1/4 hp drill press out there.
I'm doing more metal work now, so I'd like more power, slower speed, maybe a taller mounting post, and I'd also like a better chuck for more accuracy and ease of use. Bolting on a more powerful motor and gear reduction kit from RogueFab will be no problem, as is a longer post, but I don't know anything about chucks. It's always a struggle to get it tight with the key, and it wobbles/walks a little bit. I suppose I should find out if the shaft itself is wobbling as well? It's not a huge amount of wobble. The chuck that is on there is a 1/2" chuck that is either JT-33 or B-16, at least that's what the manual says.
I really like the chuck that's on my (his) newer dewalt 20v hand drill, no tools required, and it's very easy and fast to use.
I know it's a cheap drill press, and it might be more economical to just buy a new one, but I like to tinker, and I like using my father's tools, keeping the making and modifying spirit in the family :)
So, what are my options as far as upgrading the chuck/spindle/quill?
Mr. Brooks
If it would me, I would keep that machine the way it is and use for smaller tasks and then search CL for a bigger DP. Probably be cheaper to find a 1/2-3/4 hp 15" floor model than to upgrade the older one.
D
danielbuck
Yea, it would probably be cheaper that way, but I don't have a whole lot of space in my garage, so having two drill presses isn't really a route I'd like to go. Even though it would be convenient that way, one setup to go slow, one setup to go fast. And I don't want to get rid of my father's drill.
D
danielbuck
Got the 1hp motor bolted on
I think I can hear Tim the tool-man Taylor grunting somewhere :D
D
danielbuck
It may be a bit much, if it turns out to be so, then I'll put a 1/2hp motor in there. :)
Any suggestions for a keyless chuck? are they all pretty much direct replacements?
Todd.Brock
Cincinnati
Albrecht is the name for keyless chucks.
If you decide a keyed works for your application ,Rohm is a German made chuck. Can't go wrong with A Jacobs super chuck- keyed though. Good luck. Todd
D
danielbuck
Thanks Todd, I'll look into them, The Albrecht especially :) Do they install just the same way the factory chuck is installed? (tapered friction fit I assume?) Or do other items need to be changed out as well?
Packard V8
Spokane, WA
There are a dozen different chuck tapers. The last small Chicom DP I worked on had something like a JT6. Most USA small DPs used a JT33.
What you are going to find is a new Albrecht/Jacobs/Rohm chuck is going to cost several multiples of what the DP is worth.
jack vines
sasquatch12
What you really need is a BIGGER drill press,, or,, a SMALLER motor.
Your'e going to end up with a broken drill press with that motor hanging off there.
uart
Australia
That looks way over powered Daniel. A much bigger motor is not really what that drill needed, it's the slower speed pulleys that it *really* needs.
If you want a bigger motor I don't think I'd go over 1/3 or at most 1/2 horse. Remember that you get a massive increase in torque anyway, just from the gear reduction. The motor is just an overkill.
uart
Australia
BTW Daniel, just wondering what spindle speeds that the drill currently has? I've got a similar little press and my slowest speed is about 600 RPM. You need slower speed to drill much over about 5/16" to 3/8" in steel, if you don't want to abuse your drill bits.
D
danielbuck
Correct, I think it's somewhere around 500-600 RPM. I'm going to try and get it down to at least 200 for general metal drilling, and hopefully get it even slower for larger holes, although I rarely drill holes any larger than 3/4". And for holes that large I've started using stepped drill bits for holes larger than 3/8" or so, that makes pretty light work of decent sized holes even in 1/4" thick steel!
And I take my time, back the bit off and put more cutting oil in there often. The few times that I actually use a hole saw, it would be nice to have a much slower RPM.
If the motor doesn't seem to be working out, I'll put a 1/2hp motor in there.
