Show us your Well House
sbosecker
Peachtree City, GA
For those of us using a well to supply water to our homes and shops, a well house is a part of the landscape. Mine is pictured above.
Now I have some issues with mine. I think it looks very nice but, if I need to service the pump, I have to destroy the roof.
As a part of my planned shop build, I am thinking about trying to increase the production of my current well. This will probably mean tearing the roof off. When I put a new roof on, I am wanting to try to make the new one more receptive to well maintenance.
How have others built their well house to allow reasonable access to the well without having to destroy the roof?
Scott
dirtguy
In the mountains west of Las Vegas
I was concerned about the same issue when I built our well house. So I designed it with a 24" square skylight directly over the well head so the equipment would have access by removing the skylight.
The best part though is that I have never had to use it.
csp
Franktown, CO
Mine looks like Danver's. My pump is 350+ft underground and all well controls and the pressure tank are in my basement which is about 100' away from the well.
larry_g
oregon
My roof is held on with heavy hinges at the ridge. I can open the either roof section and drop the wall for small work or remove the hinge pins and remove the whole roof section.
lg
no neat sig line
southalabama
Brewton AL
I don't have a pic but I've got a buddy who built his roof removable. It has two huge eye bolts on the ridge line of the room. He can lift if up. With what I'm not sure. Bucket on tractor I guess.
jwhcars
Central PA
You could cut a hole in the roof when you need to service the well. Then mount a coupula on the roof covering the hole.
sbosecker
Peachtree City, GA
southalabama,
I've been thinking that something like this would be the way to go.
Still interested in how folks have handled this issue.
Best regards.
Scott
sbosecker
Peachtree City, GA
LG,
Interesting...
so do you do whatever you need to do and then replace the ridge shingles?
Best regards.
Scott
sbosecker
Peachtree City, GA
dirtguy,
This is an interesting idea... I'll look into this.
Best regards,
Scott
Chaz
Missoula, MT
I had a new well drilled on the property and it was pretty unsightly, so I decided that in keeping with the barn theme an outhouse would look appropriate.
It really goes well with the rest of the place, and provides a bit of humor.
The neighbors have been confused about the place since I started construction, and this should just add to that confusion. The roof lifts off for service.
sbosecker
Peachtree City, GA
I had a new well drilled on the property and it was pretty unsightly, so I decided that in keeping with the barn theme an outhouse would look appropriate...
Chaz,
Ha!
Kodak moment time when you tell your house guests that that structure is where their bath water is coming from.
Best regards,
Scott
larry_g
oregon
LG,
Interesting...
Best regards.
Scott
My ridge is covered with a flexible membrane meant for a flat roof. So I can tilt up a panel with no problem or remove 3 screws and release the membrane from one side.
lg
no neat sig line
ishiboo
Oshkosh, WI
Ditto. Pitless adapter 100' to the house, and then two pressure tanks and pressure switch in the basement.
I have another well about 20' away in the barn that has a plug but hasn't been abandoned, might repurpose it for irrigation (we have no lack of water!) and put the stuff in the barn by it.
shopnut
Florida
When we bought our vacant property in 1996, a 2” well existed and it was basically a bare pipe sticking out of the ground with the building over the top of it. When the land was sub-divided years ago, a new well was drilled for the old house on the lot next to us, and the well on our property was abandoned. All I needed to do was add a pump, tank, and associated plumbing and we had our very own running water - it was a glorious day! I felt like Tom Hanks in the movie Castaway when he finally got his fire lit.
Here is the little building where the well resides. It's nothing fancy, but its functional.
I knew early on that this system would require service from time to time, so when I rebuilt the platform, I added hinges at the base to swing it out of the way. Years ago, I used to just lift this thing right up with sheer muscle. But for a recent service of the tank, my body said “no way Jose’”. It ***** getting old, but I guess it just makes you think a little harder. I decided to devise a way to let mechanical advantage work in my favor. I mounted a temporary 2x6 sticking out the door opening so a chain could be attached to it. Then a cable and come-along winch pulled on that to lift it up.
Of course the trick was knowing exactly where to place the little pedestal and how high it should be so it didn’t flip too far over the other way. A stack of cinder blocks worked in this case and I snapped several pictures showing things in detail for next time since my memory is deteriorating at about the same pace as my body. Here are a couple of in-process shots. Arrows point to the 2x6, cable, and pedestal.
GRN96WS6
SOMD
I've never seen one of these where I live, I grew up with a well but it looked like Danver's, with the equipment in our basement (pressure tank etc).
jb3
Rhode Island, USA
I don't have a pic, but the well head in the house grew up in was in a creepy little underground room along the side of the house set in concrete, about 6 feet below the surface. The access to this space was covered with a 3x3 steel hatch insulated. (which ive had to replace maybe 4 times due to rusting out)
The recessed well had direct access to the crawlspace under the house to take advantage of house residual heat in the winter. (although I installed a door and insulated that as well, as the reverse happened, and it was a way for pipes under the house to freeze)
However, the recessed space worked pretty well keeping well components from freezing being under ground, and also as a deterrent for children. "Behave or we put you in there."
mygarageone
Munising , Mich
That seems to have been a popular set up , I have seen many just like yours in my area.
Cyberbear
California
No available pictures, but when I built my 10' x 10' pump house I used standard 2 x 4 walls and shingled 5:12 gabled roof. Code required the interior pump to be within 36" from the wall for service access, which I did.
In order to pull the well pump, I made the roof a rolling unit that can simply be rolled back for easy access when needed, then rolled back in place when done. The pump was installed at a depth of 475' in 1994, so my day is coming when the deep well pump will need pulled and replaced.
MFortie
San Diego County
Curious what your roof rolls on?
BuickFarmer
Athens, Georgia
I built this about 15 years ago out of Belgium block cobble stone from the streets of Athens, Georgia. 400 ft drilled well with 30 gl/min. Not looking forward to pulling the pump. Will have to dismantle half the ceiling and about 4 sheets of tin is all though so won't be too bad.
Stevie-Ray
Michigan's Sunrise Side
See the little wishing well? That's it. I have a well head like Danver and CSP, a 240V job with bladder tank under house about 100 ft away from it. When the pump needs service, I simply lift off this rather heavy "well" and the guys go to work. Looks a bit better than just that head. Please ignore the front porch-it's going away, in fact much needs to be done, but all in good time.
sbosecker
Peachtree City, GA
Cyberbear,
I hope it will be possible to get pictures of your rolling roof posted at some time.
Best regards,
Scott
sbosecker
Peachtree City, GA
Shopnut,
Clever... but I don't think I can pull this off with my brick well house. Ha!
Best regards.
Scott
sbosecker
Peachtree City, GA
BuickFarmer,
A handsome structure! Thanks for sharing.
Best regards,
Scott
sbosecker
Peachtree City, GA
I just walked past my well house and saw this on the northwest corner. I have to say, that's a first for me.
Best regards,
Scott
sberry
Brethren, Michigan
I believe you might be able to see it behind my date at the time, the old building an the right has been replaced.
600SL
Connecticut
Mine looks like this. I have never seen a well house. Those are cool.
Bear
Salem, Oregon
This is mine - also serves to store the riding mower and other moterized yard tools.
