mustang68408
Long time follower first time poster...
I have a town house in FL that I am currently investigating adding a 240v 30amp circuit and outlet in my garage to support some additional equipment for auto service. (i.e. air compressor, MIG welder, etc.)
I just want to add a single outlet. My fuse panel is located in my single car garage on the West wall. It's a flush mount and the garage was finished by the original home builder w/ drywall and baseboard (and it wasn't a model surprisingly enough). I am wanting to have my 240v outlet on the East wall. The garage has a bedroom above it so there is no attic so Romex is out of the question. I am considering running flexible conduit or PVC conduit with 8ga THHN wiring from the electrical panel to the outlet.
My questions are:
-Using conduit I assume I'm going to have to mate that to the electrical box so this will require me cutting drywall out to attach the conduit, correct?
-Can I run the conduit through the drywall and then secure the conduit with anchors or to the studs to run it up the wall, across the ceiling and down the other wall? (Putting in the correct 90 degree elbows when necessary)
This is probably more of a local law question, but if anybody in Tampa, FL is out there you might be able to answer:
-How about permitting? Do I have to get a permit to add an additional circuit since it wasn't installed when the house built before installation and/or inspection?
-Also, what's does the average electrical inspection cost? (Or is it necessary when I go to sell the house)
I am researching the NEC for this application and I'm a bit reluctant to spend 80-100$ (70$ digital) on a book and I am wondering if the nfpa.org website (requiring sign up of course) would give me access to the information about what I need to do to make this happen.
Thank you!
My questions are:
Thank you!
but if you know the code, you know its OK to pipe Romex, so long as you respect fill requirements.
