floor jack ID
Hiball
Missery
Oem was Walker (93632), your model was sold by Sears and it's was rated for 1 1/2 ton from the factory but later bumped to 2 tons.
H
henry29
Evansville In
That was quick, Thanks!
It's a pretty big jack to only be rated at 1 1/2 tons.
Is it a decent jack?
It pumps up ok but the handle has to be pretty far down before it starts to pump, Is that normal?
Hiball
Missery
Yes.. Decent jack, That specific model has a angled pump piston to allow it to work under a car versus straight up and down, so Yes the handle to pump contact is a bit lower but weak pump seals can exaggerate the condition so you really just need to visually watch the contact point.
Here is a good tutorial on your jack.
zkling
Hiball, what was the reason for difference in the rear wheel mounts? Ex. box tubing C vs just a flat plate. I recently picked up one of those jacks (just like Henry has) and it needs a bit of work. Haven't tore into it yet.
Hiball
Missery
Just different styling that changed with the series/models, that particular rear caster style is very expensive to replace versus the newer threaded stem style.
jdjm
Hiball. I have that same jack and it leaks oil profusely from this round plunger type thing that is attached to the handle. I don't know what its called but can that be rebuilt?
Hiball
Missery
That is the pump piston and sure it can be rebuilt.. #4 has a very nice tutorial to aid in identifying components.
