Lithium Ion Cordless Drill
Which Drill Should I Get??
  • Milwaukee
    Votes: 15 37.5%
  • Hitachi
    Votes: 3 7.5%
  • Makita
    Votes: 14 35.0%
  • Other
    Votes: 8 20.0%
  • Total voters
    40
jeepkj02
Holland, MI
I'm in the market for a cordless lithium ion drill. Would really prefer to buy something Made in the USA, but have found none! Which one do you all recommend?
I'm looking at these drills:
Milwaukee V18 550 in/lbs 3.0 Ahr
$159.99 @ Amazon
Hitachi 18V 570 in/lbs 3.0 Ahr
$199.99 @ Amazon
A little over my budget, but another option
Makita BHP454 560 in/lbs 3.0 Ahr
$305.50 @ Amazon
Maybe I can find it cheaper on eBay or used.
FNFS2000
Depends on usage, but if your an every day user stay away from big junk box store products. The lithium is an upgrade, but they still don't provide the charge cycles that old nicad packs from Metabo and other premium lines provide. (metabo does have a lithium line out now as well) not familiar with it yet still using my first metabo set, but black and decker(dewalt) milwaukee, bosch and the rest of the main stream lines rarely get passed 100 charge cycles before the batteries are garbage. Metabo is rated for thousands of charges, been using my set for years.
usa#1
I have the Makita hammer drill and also have the matching Makita impact driver. While the hammer drill is nice I rarely use it as I always go to the impact for driving screws etc. It's surprising how much power the impact has.
Moltar
Houston, Texas
The Hitachi's are rated at 1000-1500 charges.
J
jeepkj02
Holland, MI
Not really an every day use. But when I do use it on occasion, I would like it to drill through metal (sheet metal up to 1/2"), wood or drywall. So I would like some power.
How well does lithium ion hold a charge? Compared to NiCad?
wyndycity
Chicago
I have the Milwaukee drill you're contemplating and I think it's excellent.
It is a bit heavier than most cordless drills but there's no doubt it has great power and will take pretty much almost anything you throw at it. Just don't plan on drilling drywall screws to your ceiling with it unless you want a workout.
Even though The Milwaukee isn't the newer model 18V li-ion, I think that compared to the Makita, it's a great price for almost similar power.
M Fan
Oklahoma City, OK
I recommend Bosch as my first choice. As you said, can't find any made in the USA, but at least the Bosch are made in Switzerland instead of China. After that, either the Makita or Milwaukee.
J
jeepkj02
Holland, MI
Was considering that as well, but the battery is 2.6 Ahr, instead of the of 3.0Ahr the others. But it does have the most torque of any model I've seen.
speed bump
Butte Montana
Well then eliminate hammer drill because I don't see anything about concrete in your usage plans. Other than the 1/2 metal or if you plan on running some big holesaws or spade bits everything you described will be fine with just your average 14v drill so given that I would look at either.
Milwakee Compact 18v drill. A bit lower power but it weighs next to nothing and has decent battery life.
http://www.amazon.com/dp/B000WER5SE/?tag=atomicindus08-20
or a kit like this Hitachi kit
http://www.amazon.com/dp/B0011917J2/?tag=atomicindus08-20
J
jeepkj02
Holland, MI
Maybe not 1/2", more like 3/16" at the maximum.
Flash21
BigK600
North Dakota
I have that Milwakee in the first post. I like it alot. I would get Milwakee, Makita, or Bosch. You really cant go wrong with any of those.
FNFS2000
You'll get longer run time, the biggest difference is longer shelf time. Which is great for occasional users. Most people that don't use cordless tools often will find that each time they do dust them off and decide to use them they are dead. nicad and the other hydride whatever they call it popular in makita continually die "on the shelf" while Lithium holds a charge much better when not in use. They will generally provide more charge cycles, but that depends on the brand. Someone mentioned Ryobi, you have to wonder about a tool that costs the same as just a battery from another brand... How many times will you be able to charge it?
J
jeepkj02
Holland, MI
Thanks for the help everyone, really appreciate it! :)
I think I'm leaning more towards the compact drills vs the heavier hammer drills. If anyone has anything to add, feel free. Could use all the knowledge and experience possible
A lot of good info about Lithium Ion batteries.
http://en.wikipedia.org/wiki/Lithium_ion
jerk_chicken
Germany
The Bosch ones are made in CH? I'm seeing ones in Germany coming out of China and Taiwan. Hell, they're barely making the car parts in De anymore.
J
jeepkj02
Holland, MI
Sears had a Bosch cordless drill on display. IIRC, it wasn't made in Switzerland, I would have remembered if it was. I think it was made in Japan, not 100% positive.
Monte
Germany
Back in the days the Bosch cordless drills (with pistol handle) were made in japan. But nowadays ???
PS: the 36 volt and the "Brute Tough" drills are made in Switzerland (at least the models they sell in germany) the cheaper drills are mostly from malaysia , the really cheap green Bosch DIY models are made in ROC (IIRC).
Mr_fixit
Rustylvania
In my opinion, most people seems to love the drill they have at that moment. With that in mind, I love my heavy v28 milwaukee, even though that's doesn't seem to be one you'll consider...
