Great Neck ratchet compatability?
Jason280
Are rebuild kits available for Great Neck tear-drop style ratchets? I have a flex head 28014 (same head as 28000, just with flex option) that is missing the entire 3/8" drive assembly. Any other ratchets compatible with the Great Neck? I know its probably not worth spending money on, but wanted to check and see what was available. The cover plate, detent, spring, and selector are all there, just the drive is missing.
This is the sealed head style ratchet without the push button release, similar to the Snap On ratchets. Thanks!
J
Jason280
I picked it up from a pawn shop, wouldn't feel right trying to return it...
4x4gearhead
New Hampshire
You bought it with no gear/anvil? Im not going to ask lol. I bet an older snap on kit would work, the duralast has the 936 style faceplate so I dont think it would work. An older snap on kit might though as the faceplate looks to be shaped similar.
J
Jason280
It was actually given to me. I have a Snap On that has the same style face plate, but its a quick connect....so there is really no way for me to try it out.
CaseyR89
Take it back to Autozoo...they will hand you a Duralast for it.
Have you successfully done this? I tried taking in a busted great neck ratchet and they said since they dont carry it anymore I'd have to send it to great neck for warranty.
Thumper
N.E.Ga
I used to work for Autozoo......I seen it done all the time.
