Stuck Ball Joint
mike7
I have a ball joint that is stuck in the lower control arm. I've tried hitting the outside of the control arm where the ball joint goes through but the ball joint won't pop out. Is there any way to get it out other than with a pickle fork? In my experience in this type of situation, the pickle fork usually rips the boot on the ball joint. And I really don't feel like replacing the ball joint. Any ideas?
454ragtop
Carver, MA
If this is on a suspension with upper and lower A arms, I've made a tool to go between the 2 ball joints. Basically a chunk of steel with a fine threaded bolt. You take the nut off the ball joint you want to remove, and use the tool pressing against the other ball joint to push it out.
HTH, Jim
colin39
Wot car/van is it?
W0rLDWaR4
Downey, CA
Bigplum
Cotswolds England
Saw a YouTube video on this , the chap jacked the arm up , put a snug fitting nut or spanner in the gap , then dropped the jack quick , as the arm dropped down the gap closes and shocks/pushes the joint out ,
Never tried it myself , I use the biggest hammer I can find , sometimes hang a heavy bar on the bottom to give a bit of preload if it's being stubborn ,also using two big hammers either side of the joint works too
colin39
Double hammer, a club one s8de and hit the other, ive never had tbis fail, unless the sping configeration is pulling the joint close ie audi with the double wishbone set up and vans with a leaf spring that goes across the front or a torsion bar setup this needs to be realeased before undoing
cludwin
San Diego
I had one that was really stuck once. No matter how hard I hit with a fork + BFH it didn't budge.
I didn't have a torch so I ended up using a sawzal to cut the ball joint in two. Then I was able to use a press to push out the stuck piece.
Good luck!
Flange
Northern England
I use a 6 foot bar to load the joint and then give it a whack with a 2 or a 4 pound hammer. It has never failed me yet.
It is easier with 2 pairs of hands, one on the bar, one on the hammering.
michael murder
I was told to rap on the steering knuckle with a hammer until the balljoint popped out. However, it didn't work for me.
I had the same problem on a sixties car. I beat the steering knuckle and the top of the balljoint. Tried every suggestion every friend made. Unfortunately the only thing to get them apart for me in the end was the pickle fork. I just put an aftermarket boot on it after I trashed the old one.
NKlamerus
Springfield, Or. (From Florida)
I can't see the picture, but I would try using...a ball joint press?
And if 1 hammer doesn't work get a bigger one. All I've ever used is a 4lb mini sledge.
I'd also soak it PB or something of the sorts
NKlamerus
Any progress
phfittingj
Karl_B
Killeen, TX
If a few good blows to the side of the knuckle doesn't do it for me, I usually run the nut off, flip it over so I don't mess up the top of it, then run it back down upside down so that the flat of the nut is just higher than the top of the stud. If one or two good hits doesn't free it that way and I don't plan on replacing the ball joint, then it's time to use one of the various pressing methods.
Sometimes you might find it easier to replace the joint than try to save it.
4x4gearhead
New Hampshire
Sometimes a 2 ton bottle jack works for me if it is IFS. Put the tiny little bottle jack in between the two control arms just like the tool pictured above. Also it would help if you mentioned the vehicle this was on as there are a bunch of tricks to different vehicles. In most cases the pickle fork will get the knuckle away from the balljoint, but you still need a means of pressing the joint out of the control arm or C on a straight axle. Do you have an autozone near you? or another parts store you could borrow a press from?
bobcatdan
Kaukauna,WI
When brute force fails, use more brute force. I have had ball joints with a 200 lbs man hanging on the end of 5' bar while I beat on it with an 8 lbs sledge. Never meet a bail joint I couldn't get.
