i just started a job at dealership as lube tech. i do a lot of tire rotation thru the day. needed a light weight gun with some torque to break loose lug nuts. 1/2 or 3/8" both work. looking to spend $100-170 because this is only a temp job.
the only 2 things i look at is weight and trigger control. i need trigger control the most because sometimes its very easy to not get the lug nut on right and strip it if its something like a harborfreight earthquake gun
ive been borrowing guns from guys around the shop. i like the matco 1/2" gun. lots of trigger control and light weight but it keeps spinning for quiet awhile after i let off the trigger. maybe his gun is broken. im definitely not considering snap on mg725. its a very heavy gun and a lot of vibration and shock while operating 9 times out of 10 scratches the **** out of the lug nut holes.
thanks in advance
thanks in advance
