TheEquineFencer
I need to get an idea of what size beam to look for for an overhead hoist. What I had before the fire was a 14 inch web, 1/2 thick and a 7 inch flange beam 30 feet long overhead. What I'm looking at doing now is building a 16 ft. wide mobile hoist. I cannot build it fixed in place using the old anchors I had before because it is sitting right where an arch is for the new steel building frame. The arch is in the way because of an oversight on my part when I ordered the building. Even if it were not in the way I'd still have to do it different because I cannot get the steel beams I used before at the same price, $575. What I had before was built entirely of the 14x7 beams and lagged to the floor on top of a 2ftx2ftx1/2 inch steel plate into a 4ftx4ftx4ft concrete pillar in the floor with rebar. I need to be able to handle a 4000 Lb. load in the center. I've found a 24 ft I-beam, but it has a 22 inch web for $100, but I think that's a little overkill. I'm suppose to be getting another 4000 lb. electric hoist to go back on it. Once I figure out the top beam I'll figure out what I'm going to use for the uprights and such.
