I've read through many posts on this, but I haven't been able to make progress towards finalizing a purchase.
I just installed a Bendpak lift and will be doing average work using air tools. The Bendpak directions say I need a FRL so that's what I am after. I don't want to spend a lot (under $70) and prefer a combo package vs putting separate pieces together.
If what you have fits what I am looking for please let me know what specifically you purchased and if you recommend it. If it works for you I am sure it will work for my average use.
Thanks!
I spent a years working in the pneumatic's field but your question needs a bit of clarification for me. What is the air operating on your lift? Is it just for the locks or does it have an air motor on the lift pump? I'm assuming that it is just for the locks and therefore will not have any appreciable flow. You will want a small instrument oilier as anything larger will not have the pressure differential to force air into the line to do the lubrication job.
Here are a few to select from
FRL's
Can we assume that you already have a filtered, regulated air system in the shop? If so then you could get away with just having an oiler on the lift itself. Can you link to the manual online so we can look at what your doing? If as I suspect this air is just for the locks then I would not invest in anything fancy for this. I worked with many engineers that would design in a FRL not knowing anything about how they worked and the system requirements. Most never had oil out in them. Some that did have oil never consumed it because the machine was not a constant air flow, as your air locks are, and never reached the pressure differential in the oilier to produce a drop in the air flow.
Also to recap what was said above, DO NOT put an oiler at the output of your compressor, contaminating all your air lines. Put the oiler, if you must, right on the lift just before the actuating valve. Me I would not put in an oiler, I would do it manually every few months.
On edit: If you have a brand name cylinder in there like this one
Norgren You will see that they are rated for both lubricated or non-lubricated air.
lg
no neat sig line
