hoffman912
Hi Gang,
So i have a 100 year old garage is a stick building on a concrete pad, with no vapor barrier. the concrete is like the craters of the moon, has some moisture come up with efflorescence/salt. None of which is conductive to storing or working on a classic car. I need to fix a gutter causing some water to pool next to the garage, but that really does not seal in or fix all of the issues.
https://scontent-a-lga.**.fbcdn.net/hphotos-xfa1/t1.0-9/10409572_10154201496785510_2325122546170612697_n.jpg
https://scontent-a-lga.**.fbcdn.net/hphotos-xpf1/t1.0-9/10377246_10154201496865510_994550359126775791_n.jpg
there have been some sections where additional concrete was poured over top about 3/4-1"
https://scontent-a-lga.**.fbcdn.net/hphotos-xfa1/t1.0-9/10342394_10154201497355510_5430217366532616309_n.jpg
https://scontent-a-lga.**.fbcdn.net/hphotos-xpf1/t1.0-9/10320284_10154201497425510_6022158644068649346_n.jpg
there is also evidence of where the garage was expanded at one point -black top about a foot into the garage and a spot where a post once was
I want the garage to have a durable, flat and very dry surface. I want to be able to work on cars, have them on jack stands, maybe a scissor lift. I want to be able to drag engines around on engine stands and floor jacks and build and create and restore. I want to weld too, but i realize a welding blanket can save different floors from slag.
I was thinking of tearing out the floor and pouring new, but the garage foundation is the slab.. is that doable with out lifting the building? is it safe to cut out the floor, leaving the old floor in where the walls as a foundation and pouring new in the middle? i worry that is too risky... (fwiw the foundation is solid, nothings moved, its just seen better days). Also i need a vapor barrier!
i was thinking of putting a vapor barrier down and pouring a few inches on top. The challenge with this is that the new floor might not be as strong since it cannot adhear to the old floor with a 12mil vapor barrier in between. Also there is concern that this would be over the existing top plate...
a friend suggested using quickrete to fill in any crators, and break up the extra concrete poured in the one section so that everything is level, and then put a 12 mil vapor barrier over that, and cover it with race deck, garage trek, or garage deck. would this be a good solution? would the vapor barrier over the existing concrete trap in moisture and would it cause the concrete below to break up more and deteriorate more? would i need to worry about the vapor not going anywhere or causing further damage to other parts of the garage?
Bottom line i need a flat and durable work space that is bone dry and will not compromise the garage or my cars. It also needs to be affordable (2K preferable, less than 3.5 - 4K max). What would you guys do?
