Ridge beam and Rafter size
Quebeker
Montreal, Quebec, Canada
I suppose it has been discussed before but...
I'm building a 16'x20' shed. I will put my ridge beam and rafters next w-e. I've been screaning the web to find the exact calculations for my beam and rafter size but I'm not 100% sure. I've attached a picture to show you how the structure looks like.
I'm using hemlock rough sawn wood.
Beam lenght is 21'8" suported halfway.
Wall lenght is 16'
I'm using 2 2"x10" nailed together for the beam (so 4"x10") and 2"x8" for the rafters every 16".
My ratio is 6/12 or 45deg.
Can someone help me make sure my roof will hold! ;)
Tks
Mat
kbs2244
If you are putting a support post midway you only have a 10 foot span.
A 4 x 10 will be plenty strong, even in pine.
Just be careful with your splice locations.
Woody610nb
Concord, NC
Well I'm not an engineer, but your whole shed is over build, which is not a problem, I think it is very safe to say that your roof design is more than adequate for any roof load you will encounter.
Falcon67
Merkel, TX
If you have rafters with tails that sit on the top plates, the ridge carries no roof weight. If you are using 2x6 rafters, a single 2x8 ridge should provide plenty of nailing surface. Now, if you don't have rater ties (joists) at the top of the walls, then you could use a big beam supported on both ends. But you won't need 2x8 rafters. Span for Pine shows 2x6 is plenty for that span.
http://www.wclib.org/pdfs/simpspantbls.pdf
borgdog
Spokane, WA
I think we are missing a key piece to the puzzle, and that is roof load or snow load. With out that any discussion doesn't mean much.
borgdog
Spokane, WA
Very nice looking shed! Wish I could help with the structural, but I'm not an engineer and the table Falcon67 posted does not go that high on loads, I just know that it is needed, hopefully somebody more knowledgeable chimes in, but my seat-o-pants meter says what you propose should work.
Q
Quebeker
Well Dan... We're using the same meter! I would just sleep beter with a confirmation that it will hold for the next 100 years or so... ;)
I checked on Falcon's chart and it's not close to the load we have here because of the snow!
Tks
Mat
Q
Quebeker
Well I guess I will do as planed!
I will also put 2 bottom chord where I don't have a beam... A friend sugested that the walls could open up with the weight of the snow and everything could colaspse.
I'm thinking threaded rods or something... Any sugestions?
Falcon67
Merkel, TX
Good point. If he'd posted 78 lbs/sq ft snow load in the OP I would not have even bothered to post a span table. Want nothing to do with snow, personally. :lol:
DekeT
USA
I suppose you are refering to the ignorance of your answer?
If you don't like my response you may ignore it. But to call my response ignorant? Obvious you don't understand that your answers lie in a good textbook on the subject. So you ask for free advice on the web and won't know if the answers are good or bad. And to top it off you are rude to the person who is giving you best long term solutions to your problems. Who really posted the ignorance here? I know the solutions to your problem because I read books.
blazentrout
Grand Rapids, Mi
Tks
Mat
I think it will as my 100 plus year old farm house does not have a ridge pole in it and the rafters just **** up to each other.
C96
Are you kidding me, I just looked at the picture and your proposed ridge beam / rafters. Hell, you could hang beef in there along with the snow. :lol_hitti
