Changing hvac motor capacitors
87GN
phila, pa
Had the hvac guy out to check my heater and a/c as part ot the 2 twice a year maintainence contract I have. He tells me the caps for the heater motor and a/c motor are ou of spec and wanted $250 each to replace them!!! I looked them up on amazon and they are about $35 each. What makes them so expensive for him to change them when he had them in his hand? I took pictures of them to make sure I get the correct ones. Any secrets I need to know to change them other than to kill the power, remove the wires and install the wires into the new caps?
Rookie2
Western Pa.
If the unit is working.......they are ok If in doubt you can change them (or one, if it is a dual cap) when they fail the unit stops working. You'll pay list price but that should be around $15.00 - $20.00
usually i turn off the power then short each cap out with a screw driver or nut driver. then exchange one wire at a time so there is no mix up.
Rookie2
Western Pa.
The new digital meters have a micro-farad range on them. if he checked it with a digital meter then change them. $250 each is out right theft !
justsam
Penngrove, California
I too call BS on this!
Non polarized such as used here have a wide tolerance. I suspect he could go thru a whole truck full of his capacitors and not get within 6 percent. Techs typically carry universal type caps that they can configure and get close to specified value which is all you need
cort
Wow! Rip off. If the system is working, I cannot see replacing the caps. This is not high precision circuitry here. I don't think I would invite him or his company back for future service. If you do change a cap, beware that it can shock you even if the circuit is turned off. You have to discharge the cap as others have mentioned.
Scooterville
Greensboro, MD Eastern Shore
Rookie2's right! And don't forget to short it out after power is off!
I do HVAC work and I can tell ya that guy was trying to rip you off!
I changed a duel cap today for a customer. It was swollen and it was reading bad on both the fan side and hermetic side of cap. Outdoor unit would not come on at all when calling for cooling.
dogdog
I would speak to that guy and see if that cap is mil-spec and made to fly you to the moon and back plus some.
Dependents on what it is, I got mine for about $15 for a dual cap from this Temco guy from ebay. think he is also member here. or $50 for a box of 10 of different type from viot ..... having said that..... something says about that contractor is not honest. I am pretty sure 6% over or under is normal for any cap. all of them have +/- X%.
dogdog
this video I found was very informative.... even if you don't change it your self.
pattenp
Virginia - USA
Caps are listed with a tolerance % range and if outside of that range is an indication they starting to go bad and should be replaced. As a rule of thumb I think once outside of the listed UF by 10% it's best to change the cap instead of waiting for it to fail. That's why it's called preventive maintenance.
87GN
phila, pa
BS... and I have no idea what 'over 6% of their rating' even means! Does that mean they were 6% of the stated value?
You are correct. I didn't say what I meant to say. They were over 6% of their value.
joel63
Central FL
First off, how old is the unit?
If it's 10 years or more, I would change out the capacitors for preventive measures and for peace of mind. BUT not for $250!!!!
I have noticed lately that the new motor run capacitors don't seem to last very long, even on new units.
Finally if you decide to change them, get the replacements at a decent price, and as others have already said, make sure the power is off and discharge the capacitors by shorting across the terminals.
:thumbup:
byoungblood
Berryville, VA
10% is pretty standard tolerance for most caps.
While we're on this topic, my blower motor stopped yesterday. I called a guy up that was recommended to us by someone at church who deals with him regularly and told him I had it narrowed down to the motor or start cap. He said that he usually replaces the motor alongside the capacitor because (his words) "the motor usually goes out shortly after the capacitor".
I haven't had to replace a start cap on anything in ages, so is he just trying to get some extra $$$ out of the job, or is there some truth to it? I'd probably swap the cap myself, but with the wife and two year old at home, and low 90 degree temps I don't think they're willing to wait for me to get home from work to swap it out.
pattenp
Virginia - USA
I don't agree with this. Caps can go bad multiple times before a motor ever fails. Put in a new cap. Make sure it's not a run cap vs. a start cap. Being a blower motor it's most likely a run cap.
Troutsqueezer
I think it's called California, land of Prii
If it's a starter cap and it goes bad, the motor will not kick over and produce any back EMF. That means it will sit there and **** current without offering any resistance to it other than passive resistance. It can overheat and boil the annealing from the windings at that point if the breaker doesn't protect it. Maybe that's what the tech meant.
Discharging a large cap with a screwdriver will arc on your slide-on connectors, maybe damaging them. :shocking: Might be better to hook a couple of alligators to the cap tabs and then short the other ends of the alligators so the arcing occurs there. Or not.... :beer:
Falcon67
Merkel, TX
I did pay about $250 for one - but that was an after hours emergency call, 30 miles trip charge, after hours rate, list price for the part. The bill was expected - gotta pay for service. $250/each on a regular check out says "find another service company".
87GN
phila, pa
Could I use a pair of battery jumper cables to do this?
byoungblood
Berryville, VA
That sounds logical. I could hear some relays closing and some humming from the motor, but the motor itself wouldn't budge.
nehog
Jaffrey, NH
I still don't understand what you are saying. :dunno:
Capacitors have a nominal value. Say that value is 50 (micro farads is the unit of measure.) Capacitors such as motor capacitors have a tolerance, typically around 10%. IMHO, if they are 6% high, I'd ignore it. Capacitors always lose capacitance as they age, though that is not a significant factor in choice of values.
LS6 Tommy
Northern NJ
All this talk about how to short out a cap. How about doing it RIGHT- use a discharge resistor (20,000 ohm, 2 watt, wire wound). Then nothing gets damaged...
Tommy
Rookie2
Western Pa.
I'll bet your sorry you asked ! huh .
also don't expect the new cap from CHINA to last . just had one 2 yrs old fail.
Tarheelgarage
NC
Holy Chit; you are dealing with a sleavy contractor who is in the process of ape-****** you. Hope he lubed you up good before starting...:willy_nil
This maintenance contract you got yourself into sounds like it is not worth the paper it is written on if they come out to do repairs and still charge you for the repair????
87GN
phila, pa
He didn't do any work other than pm. I'm going to call on Monday to see what this plan actually covers.
zmaxmotorsports
South of omaha
:thumbup:They can actually get weak without going completely belly up,the motor will take longer to start up and run a little hotter.
Theres no excuse for the prices he was trying to charge for those capacitors,Your service guy is a serious crook.
zmaxmotorsports
South of omaha
I normally change the cap when changing a motor also,for $5-6 its a cheap insurance policy for a brand new motor in my book anyway.:dunno:
turbobu
Diversitech are made in the US, that doesn't necessarily mean they are better. Many of the Chinese/Asian caps I've been told are filled with veggie oil, which is why they aren't lasting. Price gouging on parts is quite common here. Those guys that quote $50-$65 an hour labor often times charge $120-$140 for a cap and $300+ for a universal motor. But I often get hung up on for quoting $80 an hour for labor.
kenfath
Upland, CA
I got involved in a 'service contract'. Seemed like a good idea at the time. 'I thought' the company was dependable and would be a service you could count on. I was travelling extensively at the time and thought there was some peace of mind knowing they would be a call away. Bottom line -- I fell for their BS spiel. During a regular service I had the capacitors were 'weak' claim and should be replaced now pitch. Went ahead and had them changed. Their gimmick was the 'guaranteed' price nonsense was to your advantage. Complained and got a small adjustment. Speed ahead to the next service and I'm told the evaporator coil was plugged and would have to be removed in order to clean it properly. They wanted approx $800. I 'thanked' the tech for bringing it to my attention and called the company headquarters and fired them.
Contacted a local, good reputation firm, and they have been very reliable. Their tech inquired about the new capacitors. HVAC tech was aware they are a frequently pitched item. They cleaned the coil and serviced the equipment for around $180.
I usually don't get involved with service contracts. Wish I'd listened to myself on this one.
