The Detailer
Hi guys
I have been browsing this site for a while. I can't thank you guys enough for all the awesome information and great ideas you come up with! I hope help some of you guys one day.
My project 2 car garage, epoxy is failing after 8 years of pretty tough use. Oil changes, dry steering and over 150+ details. I'm a professional detailer so my garage takes a lot of beating, especially from dry steering and machines, as well as some pretty strong solvents.
UV exposure isn't really an issue as the garage is closed except for washing. Light only enters in about 4 hours out of the day when open. Also note there are a few hairline cracks but nothing serious.
Exposure: Solvents, heavy cleaners. Acids are done outside... I recommend no one do that indoors.
Defects: minor hairlines, worn out epoxy
Square ft: 20x20
Budget: 750-1k
Tools: Small stone grinder, renting a full size from Home Depot.
I will be going with the stone grinder route for sure. I plan on doing this myself. I've always been a very good DIY'er. The epoxy I was looking it are one of these. I have been looking at metallic/reflection setups. Does anyone know of a good place to get a FULL kit, primer, base, metallic, reflector that will last.
My 2nd question is will the texture be able to adhere on vertical panels or will it run? It might look cool if it does. Here's the dilema, high walls.
I hope I can get the floor as glossy as my work, thank you guys! If you have any questions on detailing techniques or products feel free to ask away!
Square ft: 20x20
Budget: 750-1k
