Sandblasters
Crimson558
Alabama
Hey guys purchased an old house not to long ago and working on some improvement and upgrades. Previous owners were horrible painters and I have paint on what seems like every hinge and handle. I am considering getting a small blaster to help me remove paint and for whatever else may come up since I mean c'mon you can't have to many tools right! So any suggestions you guys have would be appreciated since I'm not a fan of trusting reviews at the big box store sites.
countryroad82
Kentucky
Look on TP tools and equipments site. Made in Ohio, good to deal with, and good prices. I bought mine from them 6-7 years ago and I don't know how I ever got around without it!
toomanytoyzz
Malvern, PA
Depending on your budget, compressor size and how much stuff you'll be blasting will be the deciding factor as to what blaster to purchase. The compressor can be your biggest drawback since any type of blaster likes to eat the air up. I have a nice Marco blaster and when it's hooked to my dad's Ingersoll-Rand T30 shop compressor I get a good 6-8 minutes of blasting before I need to give the compressor a break.
You can even get the one that Harbor Freight sells, but I would recommend taking it apart and wrap every fitting with plummers tape to insure a proper seal.
C
Crimson558
Alabama
Will mostly be blasting small things like the post stated so that's why I'm not wanting to go all out on a crazy expensive blaster. I currently have a 50gal air compressor which I "think" should handle most small jobs.
mo2872
Oklahoma
If you're just doing "small" items, look at one of those hopper-style "Speed Blaster" guns. I spent this past weekend blasting a whole garden cart with one, using a 60 gallon single stage compressor. It was time consuming, and worked the compressor hard, but, it kept me out of the bars, I suppose.
espyking83
Hell hole of a King Air 200
I just got this guy off Amazon for $20 and it works great. Not exactly proffessional quality but it is fully capable of what you're planning to use it for. Just cut the hose in half, get an old bucket, and adel the hose into the bucket:
http://www.amazon.com/gp/aw/d/B0007D30DO/ref=sr_sp-atf_title_1_1?qid=1403703709&sr=8-1&pi=SX200_QL40
You can use blasting sand or play sand. If you're using the playsand just fix a window screen to the top of the bucket so the clumps don't get through. Also, sand blasters need a decent compressor, make sure it cranks over 100 psi.
C
Crimson558
Alabama
If you're talking about door hinges and door hardware, I wouldn't go to the expense and effort of sandblasting. Get an old pot or saucepan, and boil them. The paint will come right off. Some people use just plain water, some put in a little soap, others put in some washing soda. Here's one example with pictures: http://anurbancottage.blogspot.com/2011/03/stripping-paint-off-hardware.html
Thanks for that link I'll give that a shot before going with a sandblaster!
Hpozzuoli
Rhode Island
This is the big HF one. It's amazing how cheap they sell this thing for. No leaks, good light, and with a vac hooked up it stays clear inside so you can see. My point is, if you have space get it or the bench top version. Either way it's a small investment for something that will see a lot of use.
countryroad82
Kentucky
Yeah, mine had an unfortunate accident with the floor and my foot after it spit and spuddered minuscule amounts of (very fine and strained) sand for the last time. Was a total waste of time and money. And yes I'm glad I threw it to the floor, stomped, and kicked that POS across the shop. It saved somebody else the aggravation, no wonder the damned thing was given to me!!
mo2872
Oklahoma
Hmm, SpeedBlaster detractors......perhaps I got the only working one they made? Score for me! LOL.
I used play sand, spread it all out on a tarp, and let it bake dry in the sun, then screened it. Worked great. :shrug:
rsanter
visalia ca
If it was me I would not be blasting all that stuff but using paint stripper in a bucket and then a wire wheel
Bob
C
Crimson558
Alabama
Yeah I'm gonna go with the stripper method after all. I have probably over a hundred hinges, knobs, and handles to clean and that's why I was considering a sandblaster. Previous owners win the blue ribbon for worst paint performance haha.
lmandell1960
you should never use playsand or any kind of sand, silicosis will develope in your lungs. get some proper blasting media.
In My Garage
ON
Does anyone have this Blast Cabinet from Harbor Freight set-up in their shop?
If so, what are the exterior dimensions of the cabinet without the vacuum canister?
And how does it come crated; fully assembled or cabinet and base, etc?
ADSR
I have this one from grizzly. Looks close to the HF you posted. It comes in a HUGE crate. You just bolt the legs on...
http://www.grizzly.com/products/24-inch-x-48-inch-Blast-Cabinet/G0708
ATC
VA
Could you measure the length of the side under the door (yellow line shown in pic)? Thanks!
If you check out their website, it shows that cabinet as a 24"x48".
I'd assume the measurement you want is 24".
Although this little doo-hickey on the back of it might throw that measurement off a bit:
cagullett1
North Texas
Definitely do not use sand. You will breathe in minute particles of glass, which is not as fun as it sounds. I got the benchtop HF one, and it works great with the black 21 gallon compressor from there.
Personally, I'd media blast them and powder coat them. If you blast them you will have to do something. The stripper method you've decided on will hopefully leave the finish so you won't have to go through all of that.
How do you like the benchtop model? I've been contemplating which HF model to get as a beginner.
In My Garage
ON
24 1/4"
the vac can sticks out 11"
Thanks!
The vacuum canister can be removed I am sure.
I want to make sure it goes down my flight of stairs and door into my basement where it will then be placed in its own sealed (but vented to the outside) room.
ADSR
Thanks!
No problem. Yes, just remove the van can, mount on the wall and run PVC to the back of the blaster.
