Which lumber to use?
FORMUD
Clayton, Delaware
Building a work bench and I'm using 2x6s for the frame work. My question is which would be a better lumber to use.....#2 & better, kiln dried , Spruce-Pine-Fir......Or, Premium #2 & better, Douglas fir?
Price wise I'm only looking at $0.12 difference per foot. So it's only going to be $50.00 more if I use the Douglas fir.
What ( If any ) is the strength difference between the two?
Milton Shaw
The higher price ones will probably be straighter and easier to work with. Some strength difference but not enough to make a difference on a well designed work bench.
Falcon67
Merkel, TX
IMHO - not enough difference to worry about. All my stuff is SPF except for the ceiling joists. My bench frame is 2x4 SPF and I'm sure I could place a complete V8 on it and the bench wouldn't care.
2drx4
Northern BC, Canada
I would use steel.
But since that isn't on your list, I would simply go and look at the quality of the lumber and go from there. From a structural standpoint, either will be fine.
abachman
Illinois
Build the frame from the cheaper wood and the top from the better wood. The frame cracking vertically will be much less of a concern than horizontal cracking on the work top.
F
FORMUD
Clayton, Delaware
I would use steel.
I was thinking of using steel. Built some benches at work a few years ago. Makes to much noise while your beating on things. Also it seems like it would send more of a shock up or arm, where wood has more give to it.
Also considered using metal just on the top. Probably going to just use 3/4" ply and some kind of thin veneer on top of that for easy replacement when it gets to beat up.
theoldwizard1
SE MI
SPF is fine.
Many times if I need 2 6' pieces I will buy a 12' and cut it in half right at the store. Longer pieces tend to be straighter and have less knots.
