Snapped Off Grease Fitting
Wamsutta
Amarillo, Texas
Snapped off a grease fitting in a brand new ball joint I was getting ready to install. The ball joints come with the grease fittings separately; meaning, you have to install the grease fitting yourself. It was going in real hard before in snapped. I couldn't use a 1/4'' drive spin handle; I had to use a 1/4'' drive ratchet because it was going in so hard. It takes an 8mm socket to drive it, so I think maybe the thread size might be 6mm, but I'm not sure. How are grease fittings sized? The ball joint has a threaded hole, which tells me the grease fitting is not the self tapping type. Right now the hole is about 7/64'', which is the inside diameter of the broken grease fitting. Irwin-Hanson has an ST-1 screw extractor requiring a 9/64'' drill bit, so I might try that first, but I'm open to any suggestions. Thanks.
OHMS LAW
Houston TX
Try the extractor if that doesn't work drill and tap a new hole or grease with a needle attachment
Olafur
Iceland
Good torx bits are quite effective extractors. Find a size larger than the hole and hammer it in - unscrew.
CZ_Greatwrench
x2 on the torx bit, a lot of times it works better than an extractor
Its not the most ethical thing to do but you could take it back to the part's store and say "It came out the box like that!"
W
Wamsutta
Amarillo, Texas
Hammered in a T-15 Torx, got it in there pretty tight too. Hooked a magnetic screwdriver up to it and the bit spun right out. It was a nice try though, and at least it didn't make it any worse. I might mention that a brand new HSS 1/8'' drill bit didn't even make a dent in it. Must be some hard steel they make those out of.
bwringer
Indianapolis
I think it would be perfectly ethical to take it back -- it's a brand-new part, but for some reason you're supposed to complete assembly (no idea why they can't be arsed to install the grease fitting at the factory...).
When you attempted to do so, the threads in the ball joint or on the fitting turned out to be defective. The threads bound up and the grease fitting broke.
You could take it back and try to find one that's not defective. Or install a new grease fitting if that's easier -- most decent hardware stores have a drawer of SAE and metric fittings.
slickstysix
I've also used a chainsaw file, or similar small file, as an extractor to get out small items like this. Hammer the tang into the broken stem and use a wrench on the remaining tang stem to back it out.
71goldss
Northern Calif
^ I've used the same method (small file) on many occasion at work! Works every time! :thumbup:
