OutLore
With the purchase of a gas grill:
http://www.homedepot.com/hdus/en_US...Grills-Propane-Tank-Exchange-Content-Pod3.pdf
I am amazed how most people don't know that the exchange tanks only have 15 lbs instead of the full 20 lbs.$13.33 (including tax) for a 20 pound fill is a much better deal than $19.99 (plus tax) exchange for 15 pounds.
Think costco is 11.50 for filled 20lb tank here.... Just use the exchanges to get newer tanks.
Right now delivered bulk propane is about $2/gal on the west coast, down from about $3 over the winter.
These "20 lb" tanks are designed to take 20 pounds of propane. They can actually fit another 20% in the tank, but that extra space is designed for expansion as the temperature changes. All propane tanks have a "tare weight" or "T.W." stamped on the collar of the tank. For a grill sized tank you simply calculate the tare weight + 20 lbs, and that's how much the tank should weigh when it's full. Most 20 lb tanks have a tare weight of +/- 17 pounds when completely empty. This means a "full" propane tank should weigh about 37 pounds.
Bring a bathroom scale with you when you get the tanks refilled.
$8.46 for 20 pounds out of my 1000 gallon tank, based on the average of my last two fills![]()
In California you aren't allowed to install a residential tank with a bottom draw, so filling from your home tank isn't feasible.
At least according to the propane guys around here. And I have no reason to disbelieve them, since they seem to have a direct path to writing the law.
I don't have a siphon, right now the grill is hooked right up to the gas. Soon though id like one!
Siphon ?
It is just a tube that extends to just above the bottom of the tank (well into the liquid propane) and connected to an external valve. Get a double ended hose. Hook to your home tank and then the portable. Open the vent on the side of the portable tank (screw) and then open both tank valves. When liquid propane starts to vent, close the vent and both valves.
Holy 2 year old thread Batman!!Same here on Aruba, filling from your home tank isn't an option either.
Holy 2 year old thread Batman!!![]()
