I picked up a 6hp pressure washer off of craigslist for $50 (I know I ****). Well it will be a true score if I can get the pressure washer gun/wand to stock leaking. I pulled it apart and initially discovered a broken rubber o-ring. Easy fix? Yes should've been. Well, about 5 o-rings later of different sizes etc, I figured that there was something else wrong.
After further internet researching, I discovered a craftsman manual (basically identical pressure washer) and it showed an o-ring that would go next to a spring washer. This made sense since the gap (first picture) is too wide for just a standard #6 o-ring. But with a spring washer next to it, it would be the right size.
So my dilemma, I went to the hardware store and bought a #6 washer but the inside diameter is not wide enough to fit around this piece. I also could not find a metric #6 copper spring washer (just stainless). The washer needs to have the exact same diameters as the #6 o-ring or else it won't work. Any suggestions on exactly what I need to purchase? I want to make my next hardware store run a complete success. I have ace hardware and home depot at my disposal. Would the plumbing section have it's own copper hardware section with the copper spring washers? I'm at a loss.
