trustmefada
First off, I will not post the manufacturing or supplier tags yet because anyone can google this, which I have and I really had to dig deep into old patents and machinery catalogs to identify the model number and year based on similar pictures.
I want to find someone who either knows just by looking at it or actually has one in use. I bought this at auction a few weeks ago and I need to know more about it. I will eventually post the info I found marked on the press, which I am stilling looking to find more markings.
Some details on the build:
-The motor is not original as you can see the back half of the tail has broken off (cast iron construction) and previous owner made an angle bracket to mount the motor.
-Originally this was Flat Belt driven.
-Has a #1 morse taper
-Hand wheel at the top left adjusts the tension on the belt (the motor can slide back and forth in place of a set of pulleys sliding back and forth).
-The chain attached to the head of the press is attached to a weight that slides through the center post and aids in adjusting the vertical height of the head.
