My 24x28 auto shop build
BigDaveZJ
Centennial, CO
We're getting ready to break ground on our detached garage that will be used for all sorts of vehicular repairs and modifications. Our current fleet is a 1995 Grand Cherokee that is heavily modified for 4-wheeling, a 2001 F250 tow pig, a 2014 Grand Cherokee Daily Driver, a 2013 Outback Daily Driver, a 24' gooseneck trailer, a 2014 28' Aerolite Travel Trailer, and an Army M416 modified to basically be a go anywhere pop up trailer. Adding the shop will allow us to more effectively work on the vehicles, store everything, and increase our ability for even more vehicles. Future plans include a GMC Typhoon, maybe an old pickup, and a 350Z at some point for my wife.
We bought the house almost exactly 3 years with plans to do the detached garage eventually. Most neighborhoods in our area have HOA's, small lots, cookie cutter houses, etc. There are a few neighborhoods though built before the mid-70's that don't have any of that, and we were able to find a great house in one of those neighborhoods. The lot is = .23 acres, which is HUGE compared to all of the newer neighborhoods around us, and we have access to a 40' wide alley behind our lot, another rarity in our area. And we bought the house from it's original owners, and are surrounded on both sides and across the street by original owners, it's a neat little neighborhood.
One of the main requirements for the shop was that the F250 fit in it, and that I could close the garage door and still be able to work on the truck. It's got just shy of 185k miles on it, and I'm sick of working on it in my driveway. That led us to the 28' depth of our shop, as I will have room to move around the truck, close the door, and still have room for something on the wall in front of it. The 24' width was about the max we could without impeding on a 12' RV "pad" that runs the entire southern boundary of our property from the alley to the street. It is currently all rock and there is an old shed in the way, but the shed will be going away within a week, and we will be concreting from the door of the shop all the way to the street.
Here is a sat view from Google that I printed out and scanned back in after drawing out some different things to help visualize what we would end up with:
The grey lines are the RV pad, and part of that will be concrete. The exact layout of the new driveway has not been determined yet. You can't really see the shed in the overhead view, but it's right off the SW corner of the attaced garage. The brown square is where the shop will go. There is an existing slab that was put down about 25 years ago for a basketball court, and we will be working on making that an awesome patio hopefully next summer.
Here is a shot looking back over the side gate towards the soon to be removed shed, as well as a horrible Juniper and Blue Spruce? that will both be removed to make way for the shop.
The shop's foundation will **** right up against the existing slab. It will come out from the rear property line about 3-4' past the existing slab, and the over to the RV pad JUST shy of where the red landscaping dividers are and through that flower bed. We tried to grow flowers there, but our 2 85lb labs didn't want that to happen.
Another angle of the backyard, looking over at the RV pad and our M416.
And looking at what will soon be the front of our new shop.
Details on the shop itself so far, 9' walls, raised ceiling (not set on this yet due to the additional drywall work needed). 18x8 insulated garage door. Separate sub-panel for electrical and replace the main box in the attached garage. Stem wall foundation, required for anything over 600 sq ft in our area. 2x6 construction to allow for more insulation in the walls. Sure there's more but I know I'm forgetting stuff.
Haven't completely nailed down how the interior will be set up, but I want several work bench spaces, a welding table, lots of storage, and lots of lights. We'll be running ethernet and maybe coax for SAT-TV out there, and will have a TV/PC monitor in the shop and plenty of audio. Audio will also be split on an A/B channel to go outside to the patio. It won't happen right away, but eventually our keezer will move out to the shop so we can have tasty homebrew on tap in the shop and close to the patio.
Basic construction is expected to be done within the next 6 weeks or so. The contractor is taking care of everything but the inside. He's running power out there and hooking up a light and a few outlets, but the rest is up to me. There is going to be a decent amount of grading required for the foundation, so I'm glad someone else is doing it!
I'll post updates as they come along.
MrJason
Bakersfield, CA.
Subscribed! Can't wait to see you build, what I've always wanted.
Build safe!
BigDaveZJ
Centennial, CO
Got the shed mostly torn down over the weekend to make room for the new driveway. The roof was a bit heavier than I thought it would be, but we cut it in 2 sections and it was manageable. We would have just destroyed it or hauled it out in one piece but a buddy of mine wanted it and has no way to get it in his yard assembled so we had to take it apart either way.
BigDaveZJ
Centennial, CO
Got some more done tonight in preparation for the foundation to be dug out. We pulled a lot of rocks out from under the large juniper bush, can't imagine these were cheap and pretty much totally hidden. We're going to move them to an area closer to the house where we moved some of the red rock that will be dug up for the driveway, might make a sweet little r/c crawler course.
And they were freaking heavy. Some were about as much as I could handle on my own.
BigDaveZJ
Centennial, CO
I think I've actually met you before, it was a long time ago though, if the Roxy you're referring to is the one from PBB. Was at a BBQ at your guys' place in Aurora? 10+ years ago.
MrRoxy
Yup, thats me. I thought your screen name sounded familiar. I know right where you are. We are down in the springs now. Good luck with the garage build and maybe run into sometime.
Robert
BigDaveZJ
Centennial, CO
Not much has changed from the outside view except it's painted and has a garage door now. Electrical is waiting on final inspection and then it's just about done and I can get to work on the inside.
BigDaveZJ
Centennial, CO
Outside is just about done. 110v circuits are all done inside, need to finish up the 220v stuff and a couple other things and then I can get insulation and sheathing up.
BigDaveZJ
Centennial, CO
The 110 is for the basic smaller stuff, lights, radio, basic power tools, etc. The 220 is for the big compressor, electric shop heater, welder, plasma cutter.
BigDaveZJ
Centennial, CO
Don't have any pictures to add really, but it's coming along a bit slower than I had planned. Between cold weather, the holidays, and life in general we haven't been able to spend as much time out there as I had hoped. But we made a lot of progress this weekend, almost done with all of the OSB on the walls, just a couple pieces to put up still. Electrical is done, will still need to run conduit for the lights on the ceiling but that's it. The Fahrenheat 7500 unit is in now too and keeps the shop nice and toasty even with no ceiling in the shop. Ceiling should be in within a few weeks though, then I can paint, then a little concrete prep and the sealer goes down and I can start moving everything in.
BigDaveZJ
Centennial, CO
Haven't pulled any of the vehicles in yet, waiting until I get the concrete sealed up since they all like to mark their territory. But I should have a few feet in between the bumper and workbenches.
The basketball court will be turned into a patio, and no kids, so not worried about a ball going through the window.
Not sure how much I've got into it total at this point.
Cummins01
Oregon
Nice looking garage! I am also building a 24x28 but it's attached to the house. I pull my truck in (Dodge 3500 quad cab long bed) and if I leave 6" from the garage door, it gives me about 5' from the back wall to the bumper. Not as big as I wanted to build (are they ever?) but it's what I could afford and I can make it work. Again, Nice work! looks great!
BigDaveZJ
Centennial, CO
Need to get some pics but we finished off the walls today and got the angled portion of the ceiling insulated. Need to make a Home Depot run in the truck for more OSB before I can do any more out there. I built a jig make cutting those sections faster. I need 29"x48" sections, 14 of them in total, and my table saw is only good to about 26". Hoping to get that done Saturday.
BigDaveZJ
Centennial, CO
Life has been a little hectic over the last 2-3 months so we've fallen a bit behind on the build. We did get most of the seams caulked today and are close to be able to start slinging paint in there. Ceiling and insulation are completed as well now too. Hopefully we can get it painted and get the floor sealed within the next few weeks.
BigDaveZJ
Centennial, CO
1st coat of paint down:
For some reason I didn't put the OSB seams on the studs, so the seams there aren't the best, but they're good enough.
jesse72
California
Great looking build and plans! Got any more pics and info of your M416 trailer? I really want to build one someday for my '66 Early Bronco to tug around.
BigDaveZJ
Centennial, CO
I had build threads on a couple forums, but I think the links on the pics ate busted now. I'll try to post some more up here.
MrRoxy
Looking good, hopefully my pad gets poured in the next week or so. Weather dependent.
Robert
BigDaveZJ
Centennial, CO
Floor is all prepped and ready for the sealer, brown Santa should be dropping it off tomorrow and I'm hoping to get the first coat down tomorrow night and then finish it off Wednesday night so I can actually start putting some stuff in there this weekend!
