Fixing 'bad' drywall tape? (BIG PICTURES)
1940_dodge
Great Falls, MT
I'm getting ready to finally paint my garage but now I'm at the point where I'm sanding all the drywall mud to make it look good and ran into this problem:
I don't know if it's because they used ****** tape, or if it's something else but you can see how it split and is now hanging down. My question is, do I need to remove all the old tape and redo it myself or is there some way I can repair this without redoing everything?
1940_dodge
Great Falls, MT
Also a couple progress pictures:
<iframe class="imgur-album" width="100%" height="550" frameborder="0" src="http://imgur.com/a/3qHm6/embed"></iframe>
38 Dodge Coupe
Delaware Ohio
It's not unusual for that to happen. I would suggest you remove as much of the loose material that you can using your small drywall knife ( 6" blade should do nicely) Then take your drywall "mud" and spread it on the area to be refinished. Embed the drywall tape into the mud and draw your drywall knife across it to stick the tape into the mud and level the finishing compound. When that dries you can do a second coat and use your next larger drywall blade to feather the compound out to further blend it into the existing drywall. If you are careful you will need very little sanding before you paint. Make sure you prime the area before you paint as it will act as a sponge and could cause the finish to look different in that area.
RivennHewn
PNW
No, you're not ready for any sanding yet.
Looks to me like you starved the joint of wet mud.
Knock it all down flat with a taping knife, then start over with the mud.
Leave a little more on, and remember to feather it out. You should end up at least 3x as wide as you show in the pic.
What level are you trying to finish to?
Looks like your at "Fire tape". or level 1
Level 5 is perfectly flat and smooth walls.
mtmgtz
It looks to me that the tape is embedded fine. I'd knock the high spots down with a 6" knife and add more mud.
Richard
If the tape is split (like he said), that isn't going to help much. It needs to be retaped.
1940_dodge
Great Falls, MT
I was worried this was going to be the answer, just means doing the whole thing all over again. One reason I was happy when I got the house was that the previous owner had already done all the overhead drywall..
Thanks for everyones input, looks like I have to redo it.
1940_dodge
Great Falls, MT
I want to get it to your level 5, ideally I'd like it to be like an indoor paintjob.
JakeKohl
Greenville, SC
whew...I see that the red is a photoshop job. I don't know if that was a prospective color or a way to highlight other things - but if you are going to paint red, be SURE to get a tinted primer to put under it. I learned this after the seventh coat on a red room trying to get it to cover. Red is a really difficult paint color because it covers so poorly.
1940_dodge
Great Falls, MT
Yeah, I'm trying to compare other colors but I'm leaning towards red right now with a white ceiling and white crown molding on the top and the bottom of the walls. I have a red wall in my house and it looks great, I just hope I don't run into any problems.
Morrison
Northeast
If you want a "level 5" job you should probably hire someone to do it. I assume you haven't done much drywall work since you were trying to sand and paint with pretty much no mudding done.
A garage is a good place to learn how to mud. Watch some videos and read up.
1940_dodge
Great Falls, MT
No, I was asking if there was an easy way to fix the previous owners work.
Trey T
Houston, TX
I started using mesh tape whenever possible except for inside corner, then I use paper tape. In my old home, I had a room with mostly mesh tape. It has been doing well, no crack, for over ten years now. This room has no climate control.
Therefore, I suggest ditching the paper tape and use mesh tape if you have to do it over again.
Floating compound is a develop skill and if you can't float it to 99% smooth, I highly suggest you don't try. The other 1% requires sanding and that's what you want to do, very minimal sanding.
Pointbock
AK
I think this is a pretty typical situation, and I'm in the same boat. When we bought the house, the garage had been drywalled and "fire-taped." The previous owner just parked in the garage, put up some rudimentary shelves and threw his lawn-care stuff in the corner.
Then a Garage Journal subscriber moved in and wanted to improve the form and function of the place. I/We hope that we can start with what we have and achieve a decent result but to get the look/finish we want, it means scraping back and starting over. It would have been easier if the fire-taping had never happened.
In my case I don't know why they did it. There are no codes to worry about, and they did so many other things half-assed that I'm surprised that fire-taping the garage was even done. If you ever meet a guy named Ben Lee that built a house and garage in Chugiak, Alaska, bang his wife for me.
mtmgtz
*makes notes* Bang Ben Lee's wife. Got it. :beer:
wnstwolf
New York and PA
10X on TreyT suggestion. The mesh is a little more money but will not split like that. I find is a lot easier to work with and usually has you ready to sand/paint after that second coat. The paper seems to force me to go o a third final coat. UMMV
atty5420
Kingman, Az
You may also like to develop a little skill with a spray bottle of water. Bone dry joints don't get along very well with mud. Keep things wet and damp. The smoothing goes a whole lot easier.
FrankieD
Piscataway,NJ
Am I the only one not seeing nearly enough screws holding that drywall up? The reason your tape split like that is the drywall is moving probably every time you open and close the door to the house. You have got some work to do there!
The Cobbler
there's definitely movement in that joint . needs to be secured or anything will let go there
1940_dodge
Great Falls, MT
Went ahead and just redid all the ceiling tape and some wall joints. Not close to being perfect but not bad for my first attempt. I can post pictures later today.
Fcvapor05
If you look at the other pics in his album, he's got what looks to me like screws at 12" in the field, which is what I've always done with good results. Can't tell on the edges, but OP it should be 8".
