ACDNate
My steel building is up and now its time for electrical
http://www.garagejournal.com/forum/showthread.php?t=252685
I initially planned to sub out the electrical. My foundation costs ended up going substantially over budget so I'm looking to save some cost by doing the electrical myself. I've done residential wiring before but not with mc, metal boxes and not in a steel building so I have some questions.
I will be using 12/2 MC cable that includes an insulated ground in the cable. 14/2 would certainly work but the differnce in cost for a 250ft roll is $8, so it's not worth having 2 different cables on hand to me.
On to the specific questions:
1. Boxes will be attached to girters in the building. Is there a particular type of screw I should be using to attach? I have a metric **** ton of screws left over from the sheating, are those ok?
2. I see there are boxes with brackets and those w/o. I can't figure out how the brackets would be beneficial in this case. Am I not seeing this clearly?
3. Looking at the metal boxes I notice they have a threaded spot to tie in a ground to the box. With the wire already having a ground, should I also tie a ground to the box?
4. Looking at MC/punch connectors I found some snap in connectors, and the clamp type connectors. I've read that the clamp types, if you aren't careful can puncture the MC. Whats the preferred connector?
5. Stumbled across a press fit wire connector by Ideal. One of those things where you say "why didn't I ever think of that". Anyway, sure they're a bit more expensive than nuts but the space saved looks to be impressive. Anyone have any experience with these?
6. I understand that in addition to the ground from the panel, I need to ground the building itself as well. Same 8' grounding rod and lug connectors? How/where should I attach to the building?
7. My outlets must be GFCI protected as it's an accessory building. How many down line outlets can one 15amp GFCI protect? Is there a limit to run length from the GFCI?
Thanks for any advice/help that can be provided.
