Do I need concrete sealer?
edcantu9
Southeastern Iowa
Having new driveway and sidewalk poured. Do I need to seal it?
I saw some of the prices and it is pretty steep. But if it is really needed then I guess I will pony up.
Any alternatives or a cheap place to get it?
Cyberbear
California
You have not mentioned what weather conditions exist where the work is to be done, but here in So. Calif. I've always used a sealer from HD as a drying retardant and it has helped prevent any cracking. You may want to seal the driveway against oil drips, etc. I used the sealer with a large pump type garden sprayer for some DIY action, works great>
kd3pc
Northern Neck
thompsons or some such will help - they are not too expensive and can be applied with a garden style sprayer CB suggest,
a lot depends on your use and your weather.
IF it freezes where you are do NOT use salts, they only make the freeze/thaw cycle worse and things will crack and heave
E
edcantu9
Southeastern Iowa
Do you have a link to the product you use? I have seen 99==$99 buckets that cover 500 sq ft. I have a 75x10 driveway. plus sidewalk and a patio which would be close to a 1,000 sq ft. And at 2 coats it comes out to $400. The product you mentioned seems cheaper and easier to apply.
I am located in Iowa where we use salt and it freezes.
Thank you for your help.
zporta
Need, no. Recommend, Yes
we use a water based cure and seal that we get from our material supplier for around $110 for 5gal
