Power Supply
MartyO
N.W. Georgia
I need a twelve volt power supply that I can plug in to a 110v outlet that will let me power car headlights.
Thoughts? Suggestions??
rockwithjason
Las Vegas
a quick search of amazon.com turned up about 1000 options. for head lights you will need a pretty stout one. i notices a 30a version on there for about 40 bucks.
dogdog
think that is too expensive. typical headlight is about 65 Watt? you would have needed 2 of that to power 10x 65Watt headlights or more if they are 100Watt bulbs no?
Maybe 10 of these (dependent on your wattage needs) cheap enough $13 each?.
If I remember correctly they used to have those 12V lamps that are power converted with toroid transformers. you wouldn't like the price for those.
http://www.amazon.com/DELED-110v-220v-Switching-Converter-Protections/dp/B00JX8ZD3E/ref=sr_1_27?s=electronics&ie=UTF8&qid=1406035508&sr=1-27&keywords=12V+power+supply
hilld
Vancouver, WA & San Juan Island, WA
Close, what you probably need is an automotive/motorcycle battery and a trickle charger unless you plan on running the lights full time, then you need a real charger. Most power supplies that can provide that kind of power, cost an arm and a leg.
With the battery you can power the lights for a longer amount of time and the charger can catch up when the lights are off.
volleyball
NY, not NYC
What are these lights for? If for decorating and you don't need all that light, get lights that takes bulbs and putting lower power bulbs in them.
48RON54
Inland Empire, CA
Why not get a battery charger / jump starter. Should be able to power most anything you need.
Tom
This. Though I'm running under the assumption you are just testing things and I could be completely wrong. I test most DC things with a simple cheap charger you can pick up anywhere.
justsam
Penngrove, California
If all you are going to power are filament type bulbs, you can just use a step down transformer. The bulbs don't care about AC or DC. An old landscape transformer at 12 volts would do it.
MartyO
N.W. Georgia
I have an old GMC grill with great patina and three of the four head lights remaining. I want to mount the bumper either inside my shop or on an exterior wall and be able to power the lights when I am in the mood. As a result, I want to keep the bulbs in it that are already there.
I found a decent power supply on eBay that looks like it will do the trick but in the next day or two I will try an old, spare battery charger and see if that does the trick for me.
MartyO
N.W. Georgia
Good point! I did not think of this.
hackwelder
The lights will run fine on AC as was said, however they pull roughly 4 amps each so that would require an fairly hefty/expensive transformer rated for about 16A@12V or 200W.....FWIW the lights could also be wired in a series parallel combination to run on a 24V transformer (or even all 4 in series on a 48V transformer)....anyway around 200 watts and maybe about $40-60 in any case.
If you don't want them at full brightness a wimpier lower voltage transformer would work, the bulbs don't pull nearly as much current then.
MartyO
N.W. Georgia
I kind of want the dimmer, aged out look.
hackwelder
9 volts would probably be about right for that...maybe wire all four in series and power with a 36V transformer? Not sure what the total power requirement would be but it would be MUCH less than the 200W 12V would require.
maynard9089
I would modify the headlight to accept something else such as LED. I wouldnt want bright lights in my face all the time. Just want the effect without the affect.
Beemer533
Syracuse, NY
PC power supply won't work. Most don't put out a lot of current at 12v.
A typical 500 Watt Atx supply can provide well over 10 amps on the 12V rails.
I turned one into a bench supply using this wiki.. Pretty easy, works great. There are quite a few tutorials out there.
http://m.wikihow.com/Convert-a-Computer-ATX-Power-Supply-to-a-Lab-Power-Supply
I used an old one I had lying around, and I can easily pull 15A out of it. I only ever went that high so far when I first built it, but I have no problems pulling 5a from it regularly.
Here is a 500 Watt supply on Newegg for $40.. Shows 16a on one rail, 18a on the other.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817148027
You shouldn't have any trouble getting 4a out of any atx supply that is operating correctly, even a 250 Watt one..
ForceFed70
BC, Canada
Another vote for a PC power supply. Super easy to modify and will provide all to current needed. Everyone has an old PC kicking around.
He could even use the 5V rail to get a dim light if he only wants the lights on for effect. Or wire the lights in series for 6V each.
volleyball
NY, not NYC
You will need a pc supply for each light unless you have a high power supply. You also waste a lot of power because of the unused +5v, -5v and -12v.
Now if you took a supply and engineered it to change the +5 to +12 it might be worth it.
You can take headlights and remove the filament and put in a 120v ac bulb and socket into it and do away with DC altogether. Put it on a dimmer too.
jkwilson
SW Indiana
You'd be surprised. Tungsten filaments have an unusal VI curve where it's really steep at low voltages and almost flat at higher voltages. A 10 to 25% voltage drop gives a very small current drop.
Before semiconductors, light bulbs were often used in electronic circuits to take advantage of that effect.
hackwelder
Am aware of the non linear relationship, though even if current remained the same the power requirement would then drop off as the voltage, i.e. 25% less at 9V vs. 12V. Since I was curious how a headlight conducts at reduced voltage (and am slightly nerdy ;-) and had everything I needed on hand (a HL, a HL socket, a variac, and 2 DMM's) I decided to experiment and the results are below.
Also took a photo of the bulb at 6 volts and since the OP is looking for a dimmer decorative effect that would probably do the trick and a 80W 6 V transformer is only about $28 (4 bulbs would require about 60W @ 6V)
http://www.mouser.com/catalog/catalogusd/647/2287.pdf
MartyO
N.W. Georgia
Holy smokes! I knew I should have paid more attention in science class!!
THANKS!!!!!
hackwelder
THANKS!!!!!
No problem at all, am glad I could help...I was curious anyway and FWIW I fool around w/ vacuum tube electronics as a hobby so the test gear was already on my workbench and the headlight was on a nearby shelf, only took few minutes.
