ctgoodman
I've been trying to figure out what I want for the longest time. I'm shooting for a max size of 40x60 or just short of that. With that in consideration I have several local builders say a Steel building or Pole Building will give be the most bang for the buck. I'm having some issue finding what I feel is a reputable steel building manufacturer. The few I have contacted where extreme high pressure "you got to jump on this deal today to get it at this price". That's a major turn off for me. I've however have had great experience talking with DIY Pole Barns and Hansen which supply post frame kits. The contractor that built my house has put up several pole buildings in the area and does a great job at it. I just still have this hang up about any type of wood making ground contact.
I guess what I want to get some consensus on the longevity of this type of building. So I have a few questions.
If you have a pole building that is 25 or more years old can you post a pic of your skirt board or splash plank? I'm concerned somewhat with it's appearance after many years exposed to the elements.
DIY Pole Barns says they use MCA treated lumber. I always heard the CCA stuff is the best but will I get the lifetime of performance out of the MCA treatment?
- How long has your pole building been up?
- Have you had any issues with rot of the poles or the splash plank/skirt board. Especially if you have concrete poured up to it on the outside as well.
- Have you any issues with bugs? ie: termites
- Have you had any regrets about building this type of building?
- I plan to occasionally knock the chill off with a wood stove. What would you, at minimum, recommend I install to prevent interior condensation?
- About where are you located? I'm in Central NC.
- Have you had any issues with your metal siding rusting near the bottom or where it contacts the treated lumber?
