The mean fish
- Joined
- Aug 31, 2010
- Messages
- 323
I've got a steel 12 x 14 enclosure which I'm using as a J box in my shop space, I've got 2 PVC 1 1/4" conduits running from this J box to my breaker panel about 30' away and I'm running EMT all over the shop back to this J box. I'm going to end up with about 9 outlet circuits and 2 lighting circuits running through this box. Everything is running over #12 THHN and I'm thinking about installing a ground bar in this J box then running some larger THHN ground wire back to the ground bar in my breaker panel.
I've got some green #4 THHN I could use for this and I had planned on grounding this enclosure anyway. As long as I'm using big enough wire is there an issue if I combine the grounds on these 20amp circuits inside this J box?
You can see the J box in this photo, right now I have my lighting circuits running through it but I haven't installed the ground bar in the box yet.
