Say it ain't so! First time Wright has ended up on this list!
Added.
Kind of surprised me, too.
Added.
Wage we need to set up one for Carlyle tools.
Since there putting out service carts that look like Matco's, along with impact guns, and hex screwdrivers that look like s&k/matco style.
When i work on monday, i'll grab the napa shop catalog and do some hunting.
I've bought more than a dozen tools, thanks to this list thread. Thank you.![]()
Impact Sockets:
23766 3/8" Pinless Impact Universal Joint - Matco BUP2BB, Armstrong 19-947
23765 1/2" Pinless Impact Universal Joint - Matco CUP2BB, Armstrong 20-947
Pick Sets:
CHP4-L 4 Piece Hook & Pick Set - Ullman CHP4-L, Matco CHP4L, MAC PSCHP4L
Pliers:
42454 3pc Flexible Line Clamp Pliers Set - Matco LCS3
45433 2pc Ergonomic Adjustable Pliers Set - Knipex 9K 00 80 25 (Cobras)
47412 8" Internal/External Retaining Ring Pliers - Channellock 927
47050* Mini Hose Pinch Pliers - Imperial HP54, KD 3791, SK 7601, Blue Point PHP3, Matco HP54
47051* 9" Hose Pinch off Pliers - Imperial HP55, KD 3792, SK 7602, Blue Point PHP1, Matco HP55
47060* Heavy Duty Pinch Pliers- Imperial HP56, KD 3793, SK 7603, Blue Point PHP2, Matco HP56
*All 3 in Craftsman set 74Z706
950465 6pc Camlock Retaining Ring Pliers Set - Imperial Stride IR-6CK, Snap-On PRH406, Matco MST4306, SK 7780, Urrea 370L, Armstrong 68-056
950464 12pc Quarter Turn Internal/External Snap Ring Pliers Set - Imperial Stride IR-12K, SK 7612, Proto 360B, Snap On (BP) SRPC112 , MAC PK1250, Matco MST1225, Urrea 360B
47394 3pc Quick Switch Snap Ring Pliers Set - Lang 1465, Channellock RT-3, Matco SPRC3A, Snap On PRH503, Wright 9H1265K
Screwdrivers:
49020 6pc Professional Screwdriver Set - SK 86330, Armstrong 66-621
49300 5pc Professional Screwdriver Set - SK 86331
49305 4pc Professional Stubby Screwdriver Set - SK 86335
49302 7pc Professional Torx Set - SK 86333
41612 Professional Scratch Awl - Armstrong 66-450
Pry bars:
43278 3pc Hard Handle Pry Bar Set (12", 17", 25") - Wilde 3-SQ.B/CL, Master Mechanic 134484
43275 12" Hard Handle Pry Bar - Wilde 7B
43276 17" Hard Handle Pry Bar - Wilde 12B
43277 25" Hard Handle Pry Bar - Wilde 18B
43285 31" Hard Handle Pry Bar - Wilde 24B
43286 36" Hard Handle Pry Bar - Wilde 28B
61355-998 3pc Professional Pry Bar Set - Mayhew 61355
Pick Sets:
CHP4-L 4pc Hook & Pick Set - Ullman CHP4-L, Matco CHP4L , MAC PSCHP4L
Air Tools:
19905 1/2" Professional Impact Wrench - Ingersoll Rand 2131
Specialty Tools:
40804 25 Blade Master Feeler Gauge Set - Proto J000AA, MAC FG002
52060 5pc Bolt Out Set - Irwin 394001
52061 5pc Bolt Out Upgrade Set - Irwin 394002
52166 10pc Low-Profile Twist Socket Set - Matco TSSLP10C
52105 40pc Master Rethreading Kit - Kastar 972, Snap-On RTD40, MAC TRCOMBO
9712750 48pc Master Rethreading Kit - Kastar 971, Snap-On RTD48, MAC TRCOMBO-48
Screwdrivers
J1208SCP 8pc Duratek Combination Screwdriver Set - MAC SDB8CR
Pliers:
J278GXL 8" XL Series Slip Joint Pliers - Wilde G263FP.NP/CC
J260SGXL 10" XL Series Groove Joint Pliers - Wilde G271FP.NP/CC
J228GXL 8" XL Series Needle Nose Pliers - Wilde#
J209GXL 7" XL Series Heavy Duty Diagonal Cutting Pliers - Wilde 4276/CS
J360A 6pc Convertable Retaining Ring Plier Set - Imperial Stride IR-090K, Armstrong 68-015
360B 12pc Quarter Turn Internal/External Snap Ring Plier Set - Imperial Stride IR-12K, SK 7612, Matco MST1225, Snap-On SRPC112, MAC PK1250
Specialty Tools:
JFE96030 12pc Terminal Tool Kit - Sealy VS920, Snap On TT12KT, Matco TTK031, MAC TT96030, Cornwell JS96033
J000AA 25 Blade Master Feeler Gauge - Craftsman 40804, MAC FG002
J000BR 6 Blade Non-Magnetic Feeler Gauge - Snap-On FB325A, Matco FG23A
J00MM25 25 Blade Metric Feeler Gauge - KD 2274, Matco MG25, MAC FG030, Cornwell RBFG30MM
Screwdrivers:
86330 6pc Cushion Grip (Pro) Screwdriver Set - Craftsman 49020, Armstrong 66-621
86331 5pc Cushion Grip (Pro) Screwdriver Set - Craftsman 49300
86335 4pc Cushion Grip (Pro) Stubby Screwdriver Set - Craftsman 49305
86333 7pc Cushion Grip (Pro) Torx Set - Craftsman 49302
Pliers:
7601 Mini Hose Pinch Pliers - Craftsman 47050*, Imperial HP54, KD 3791, Snap-On PHP3, Matco HP54
7602 9" Hose Pinch off Pliers - Craftsman 47051*, Imperial HP55, KD 3792, Snap-On PHP1, Matco HP55
7603 Heavy Duty Pinch Pliers - Craftsman 47060*, Imperial HP56, KD 3793, Snap-On PHP2, Matco HP56
7612 12pc Quarter Turn Internal/External Snap Ring Pliers Set - Imperial Stride IR-12K, Snap-On SRPC112, Proto 360B, Matco MST1225, MAC PK1250, Craftsman 950464, Urrea 360B
7780 6pc Camlock Retaining Ring Pliers Set - Imperial Stride IR-6CK, Matco MST4306, Snap-On PRH406, Urrea 370L, Craftsman 950465, Armstrong 68-056
NOTES:
Currently, I will continue to leave off other "Industrial" brands (Williams, Armstrong) since the majority of their tools are only available in more expensive truck brand versions.
Thanks for the info. I'll have to look into some part numbers to get on the list.Okay so I messed up and posted on the stickied thread but I have the following info:
Matco has all their holesaws, holesaw arbors, holesaw kits and cutoff wheel arbor made by the M.K. Morse company in canton ohio. I know cause I used to work there. Pretty sure they make their hacksaw blades and reciprocating blade as well.
Matco has their Allan bit sockets made by wright tool.
I looked into this a bit, and I believe the ATD and Nesco sets are overseas made vs the USA made Irwin sets. If anyone is able to confirm or deny that's the case, I'd appreciate it.I may be wrong on this, but it looks to me like the ATD-277 117 piece tap and die kit is the same as the Irwin/Matco/Snap-on/Mac/Cornwell 117 piece kit. It looks like at some point the blow-molded case changed. If it is the same set, it's significantly cheaper than even the Irwin.
ATD
Irwin
Matco
Snap-on
Cornwell
Nesco
Awesome to hear, and glad everyone was able to help!I've bought more than a dozen tools, thanks to this list thread. Thank you.
Thanks for the info. I'll have to look into some part numbers to get on the list.:
I'm looking for a specific tool, made in USA, a truck tool equivalent.
a cooling system pressure tester , the hand pump style, with heavy duty truck cap adapters but also automotive adapters. If anyone can recommend me anything it would be appreciated. Thanks!
This should fit the bill.
Deluxe Cooling System Pressure Tester
Matco PTK70888 - $214.95
Craftsman 70888 - $107.99
Look real similar to meAnyone know if this blue point is a rebrand?
Snap on sp500
Thanks guys![]()
Snap-On
Set, Socket, Tap, Adjustable, 2 pcs.
Item: ATSSET
http://store.snapon.com/Adjustable-Tap-Sockets-Set-Socket-Tap-Adjustable-2-pcs--P647396.aspx
Irwin
Adjustable Tap Set, 2 PC, Socket - 3095001 (HAN3095001)
http://www.zoro.com/i/G1322054/?gcl...gfCjeMu9WGFP_YdrOR_W-lwsXh8n_hr2dTBoCxxHw_wcB
also
PBT-70888 Cooling System Pressure Tester 135.99
and
Craftsman outlet $23.93 - $77.93
wow they are clearing them or something.
Some of those "Williams" tools are considered to be obsolete Snap-On tools, not exactly an equivalent.
I know this was discussed in years past, but I wonder how many of the OEM tools have slight variations -- maybe they’re significant or maybe they’re not. But it’s not unheard of for a company who contracts with an OEM to call out certain specifications in a tool that the OEM “house” brand might lack. That’s just something to be aware of. Whether it’s different material, different construction, modifications, parts, etc. Again, may or may not be a big deal, but just something to be aware of. I’ve seen a few examples where guys thought they were getting the same thing but there were differences in material and construction that really affected the price.
Pray tell what are the differences between the Craftsman and Proto? I have the Craftsmans and think they are really nice.
Explanation for Clik-Stop: http://toolguyd.com/proto-clik-stop...il&utm_term=0_64ed05eb8b-92dd9a458e-298969157Pray tell what are the differences between the Craftsman and Proto? I have the Craftsmans and think they are really nice.
Case in point would be Western Forge adjustables... Big difference between the Craftsman and Proto.
Most people ignore the "made to spec for xyz" part and just declare it the same when it may not be...
This is awesome. Someone should compile this and make a phone app so you can get on these tool trucks and laugh at the driver when he quotes you.
"Yea right Dooood. $55 for an $8 Stanley hammer."
