Need framing nailer recommendations
75gmck25
Alexandria, VA
I need to buy a full round head framing nailer to use for my basement and garage finishing and I'm looking for recommendations on a reasonably priced product. It will only be for personal use.
The Porter Cable FR350B seems to be a good product in the $200 price range, and the Hitachi NR90AF is about the same price and has similar reviews. I could also step up to the Hitachi NR83A3 for about $270, but I'm not sure what extra capability I get.
Any insights or suggestions?
Thanks
Bruce
75gmck25
Alexandria, VA
Yes, that's why I'm looking at full round head (FRH) nailers.
There does not seem to be a significant price difference between the two types, so FRH seems to be the better choice.
Bruce
MoonRise
The 'big' Hitachi is the one to get and not look back.
The PC is OK, the other Hitachi I don't remember, but the 'big' Hitachi was the only one IIRC to shoot full length (3-1/2 inchers) into LVL beams, full-depth with no issues or 'proud' heads.
And yeah, FRH is the way to go. No 'worries' about code issues or what-not. IIRC, clipped-head gets a few more nails in each 'stick', but some 'codes' don't allow clipped-head.
YMMV, etc, etc.
MagKarl
Olympia, WA
I bought the Porter Cable last year. Works great in my opinion.
Just bought a Bostitch F21PL, this one has two tips, one for framing, the other for connectors. The second tip is supposed to be "positive placement" for shooting nails into holes in brackets such as joist hangers. My brother is a builder and says this one is the one to get if you do many brackets. Paid $200 on Amazon.
http://www.bostitch.com/default.asp...esc=21°+Industrial+Framing+Nailer+System
67carl
California
I bought a used Bostich and it's never failed. If you don't plan on using it for your job (i.e. just infrequently around the house) think about getting a used one for less money.
Angelfire
New Mexico and Ireland
I really like my Bostitch F21PL. Works well for standard framing and is very helpful for attaching connectors. The framing crew next door borrowed it one day to attach a bunch of connectors.....had to work them pretty hard to get it back!
75gmck25
Alexandria, VA
I appreciate all the recommendations. Based on availability I think I've narrowed it down to the Hitachi NR83A3 ($270), Bostitch F21PL ($220) and the Porter Cable FR350B ($200). The MAX SN883RH2 ($200) is also still a contender.
Home Depot carries the Hitachi and Porter Cable models in the store, where I can get a 10% military discount, but the others I would have to order through Amazon.
Thanks,
Bruce
gml1998
Paslode cf325 cordless. shoots offset fullhead nails. Did I mention its cordless.
BDBLK2K3
Concord NC
Check out big sky tools . reconditioned hitachi .
I have got a compressor and all my guns there looked like new ,
Bob
87jeepwrangler
The bostitch is awesome. Works flawlessly. Available at all the stores, as are the nails.
Trigger can be switched to suite you (trigger then tip contact, vs tip contact then trigger).
Some of the best money I ever spent.
Edit: easy nail height adjust too. No tools needed. I know the paslodes need an Allen key to adjust height (I adjust it all the time depending whether I'm toe-nailing, normal framing, or putting up sheathing).
oltruckag
*******, GA
When I built my shed I used the campbell hausfeld kit from Lowes - I think I paid $129, looks like it's $91 now on the website. My store doesn't show stock, I wonder if this is even available any longer...
While I wouldn't use for framing if it was my day job, it is certanly up to the task of DIY framing projects.
Tyson
lbperry
North AL
Angle on Framing Nailer
Not to try to steal your thread; but what's the significance in the head angle in a framing nailer? They seem to vary from ~20 degrees to ~45 degrees. Will be using it for typical DIY construction. Appreciate any input.
Thanks
strnge
MD
Go to a Pawn Shop. They are all over the place there and you can get them cheep.
bad_idea
Pasquotank, NC
I bought a Duo-Fast CN-350b used for $12 that needed a rebuild. The o-ring kit cost $14 and about 2 hours of me swearing at this thing (should have only taken 20 minutes). Getting the rebuild right was a PITA, seeing as I have never rebuilt one. BUT, now that I got it working good, it works great. Best $26 I have spent in a while. What I'm getting at, shop around for a used one. They are easy to rebuild and since you are using it for home use, you have the time to fight w/ it if it gets stubborn.
Backlight
Ontario Canada
I also have the FR350B - works just great, no issues. I've had it for about 3 years, use it around the house and cottage.
KANSASBOY
I bought the Porter Cable FR350B because of the trigger it has the Selectable trigger with trigger lockout for restrictive or contact actuation mode .This helps when you doing a lot sheeting .
mtmgtz
Porter Cable used to be a real quality tool (routers, sanders, etc.) prior to them being bought out by Black and Decker. Now it's mostly chinese/mexican junk. Hard to find anything that isn't chinese though these days.
I'd buy a Paslode, Hitachi or Senco. I've used Bostitch framing nailer (I have a Bostitch finish nailer which is fine) and it was a pile compared to the Paslode. We only used the Bostitch when we nailed on brackets since the Paslode we had didn't have that capability. The Hitachi roofing nailer was the best of the three roofing nailers we used.
cashishift
Omaha, NE
I have the same thing.. I got it for free, and my father has paid for the repair twice. :bounce:
Next time though, we might be forced to get a new one. As some parts are becoming scarce.
