AC Delco hand held tachometer 1940-1950
walz
Alaska
What I have is a hand held tachometer that my father in law had used forever, until he died of old age. It's been sitting for ten years before I was able to use it.
Anyone who has one of these little gizmos, I need some help, when I place it on the engine belt, it maxed out the RPM's. I've tried it on several vehicles and I get the same result. :headscrat
I know this can be fixed, however I need someone who has one to give me an answer I really don't want to experiment with a really old tool that will work if I can get educated on it. :headscrat
(btw: these photos represent my tool, I sourced them off the internet.)
And thanks for your site, it's a great place to learn about stuff, this place helped me restore two old tools and I'm using them all the time.
91bronc300
I think that that contact tip might be worn. The way you are trying to use it would be if you were trying to measure surface feet per minute which I don't think that tool is setup to measure (but it might be). I think it's supposed to have a tip with a cone that you can put into the center of a rotating shaft.
mitusa
SW Oklahoma
This ^^^^^^
W
walz
Alaska
:headscrat
I thought you place the tip on the belt of a running engine, like the alternator, and it gives you the rpm.
I'm lost on what it does..........:wtf:
Advan
Ontario, Canada
Here's a video on using a little starret. Disregard the babbling, and forward the video to about 9:00.
<iframe width="560" height="315" src="//www.youtube.com/embed/4RLnwgp6YcM" frameborder="0" allowfullscreen></iframe>
W
walz
Alaska
Now that make sense, I'm now on track, so I put it on the end of the pulley not on the belt. OK cool I'm going to try that and I am glad someone helped me on this learning curve. Again thank you.:bowdown:
W
walz
Alaska
I Just checked this out and it works great.:bounce::bounce:
This is a great tool, I'm glad it works even if it's 60+ years old.:bounce::bounce:
They sure don't make them like this anymore. Everything is made in China, and it don't last long.:sad:
Packard V8
Spokane, WA
I've never seen the Delco, but Stewart-Warner still makes one which works the same principle.
th
jack vines
DekeT
USA
I think you are supposed to put it in the center of the rotation. Try using it on the end of a crankshaft. Putting it on a belt will not tell you anything.
ttpete
Dearborn, MI
I have several that are a bit more sophisticated. They're mostly used in machine shop work to check spindle speeds, and they also have attachments to directly read surface speed in feet per minute.
W
walz
Alaska
That's what I said my problem was, I was not using it correctly, without someone to show me how to use it I was lost.
MikeF2316
Thornhill, ON
My uncle had one of these. He sold radiators for huge stationary engines, they used this to make sure the electric fan motors were up to speed.
W
walz
Alaska
It's a really great tool, I'm still sifting through my father in laws tools, finding things like this that are a real treasure. This tool has lasted one generation for 60+ years and now I am using it. How cool is that.
