Power cables for power tools
Alvetro
Hi to all the Garage Journalers from Cape Town. I am looking for some advise regarding power tools and their power cables. I have trying to setup some storage for my power tools but the thing that always bugs me is the power cables which just makes it look untidy. What I am thinking of doing is to cut short the power cables to about 250mm from the tool and then fit a male kettle plug on the end. As I have plenty of these kettle plug leads I can then store them separately or just interchange one. These are the plugs I have in mind.
What I want yo know is if there would be any major issues with these. Your help will be greatly appreciated.
Thanks
6m x 9m garage/workshop
67 LHD split kombi walkthru
71 Karmann ghia
Happiness is not having what you want but rather wanting what you have.
sands35
St. Joseph, MI
None - just make sure the female end is on the cord, not the tool. They basically turn into extension cords.
KenB
Pittsburgh, PA
Rather than modify your tools -- voiding your warranty and killing any resale value -- why not try to find a more suitable storage solution? Here's one idea, which uses a small cubby under each tool for cord storage: http://www.woodworkerblog.com/power-tools-storage/. A second row of cubbies could be used for storing blades, bits, etc. You could build some of these inside a cabinet, if you didn't want the tools out in plain view.
Ken
JoeFin
NorCal - where the Rednecks Race
Most quality power tools come with a storage case.
However for those that don't, since it seems to be an issue for you, I would build wooden cases and mold the inside with foam or expanding spray foam and a sheet of vinyl
A
Alvetro
Ken
Thanks this looks like a good idea. Although warranties are not of a concern as all the tools have expired already.
wssix99
Chicago, IL
Many power tools (circular saws, etc.) draw enough current that they would exceed the capacity of this type of plug. Power tools also take a good bit to strain on the cords, and this type would just pop out on every tug.
